Body Work - Ford Truck Enthusiasts Forums
View Poll Results: How does the price sound?
High 1 6.67%
Average 3 20.00%
Low 11 73.33%
Voters: 15. You may not vote on this poll
Body Work
Old 11-02-2012, 08:37 AM
Stu13's Avatar
Stu13 Stu13 is offline
Stu13 is starting off with a positive reputation.
Body Work
I just got a quote from a backyard retired body shop guy to do all of the body work on my truck. It needs cab corners, a bed fender, the whole drivers side floor board, a rocker panel, two doors swapped out and hung, all of the dents fixed (a good amount), and some miscellaneous rust fixed around the truck. All rust will be cut out and all new parts will be welded in and primered. He does quality work and takes his time. His quote was 1100. I'm wondering if this sounds high or low. All awnsers are appreciated. Thanks.
Old 11-02-2012, 08:48 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I voted "low", but I should explain that I've not had that work done nor quoted so I'm not really qualified to say. However, I'm thinking of doing almost exactly the same work myself and if I had a quote to do for $1100 in the kind of style yours is supposed to be I might jump at it.
And, now I'm signed on to follow this so's I can learn.
Old 11-02-2012, 09:06 AM
Stu13's Avatar
Thanks for the vote. I should also mention that he knows the truck is going to be black (shows everything) and said it will be perfect front to back when he's done with it.
Old 11-02-2012, 09:08 AM
Galendor's Avatar
Galendor Galendor is offline
Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.Galendor has a good reputation on FTE.
If he does quality work and takes his time as you say, then that quote sounds low to me considering the amount of work described.
Old 11-02-2012, 12:04 PM
81ChopTop's Avatar
81ChopTop 81ChopTop is offline
81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.81ChopTop has a very good reputation on FTE.
I voted low also. Just for the cab corners, it'll be over $500 at any body shop. Adding everything up (guesstimating) I would think a normal shop would be over $2-3000 to do the work. If he's really that good, that price will be hard to beat. Floors, rockers and bed sides take a lot of time to do correctly. I'd say go for it, just make sure if the price would go any higher, he talks to you first before going ahead with any more work.
Old 11-02-2012, 03:52 PM
Stu13's Avatar
Thanks for the response. I also forgot to mention I have to buy about $200 worth of parts
Old 11-02-2012, 08:48 PM
86fordtruck's Avatar
86fordtruck 86fordtruck is offline
86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.
It sure sounds low to me. If he does good work, its a deal. I always worry when it seems to be to good to be true, so buyer beware. But if he does good work and that is the price, I'd jump all over it.
Old 11-03-2012, 07:53 AM
ozark1 ozark1 is offline
ozark1 is gaining momentum as a positive member of FTE.
I would say.."Bargain"..even better than low..However..it's been my experience that the "retired backyard craftsman" usually takes 3 times as long to do anything..His projects come first....
Old 11-03-2012, 09:04 AM
Stu13's Avatar
Quote:
You bring up a good point. He estimated it would take him about a week. Also, I'm in no hurry.
Old 11-03-2012, 09:44 AM
Gary Lewis's Avatar
Since he's a retired body shop man he knows how much heat he can put into the panels w/o warping them, and that will cause him to go slowly. Further, since you are going with black the truck will have to be almost perfect, as you and he already know, so having someone that will do it at their own pace w/o the pressures of needing to get it done to move to the next job is a big plus. So, I'll just say that if I had that offer I'd jump at it - even though I have the tools with which to do it myself.
Old 11-03-2012, 10:42 AM
Stu13's Avatar
Quote:
Thanks for the reply. You sound like you've done black paint jobs before. Do you have input on them? I know they look great but I will still be using this as a work truck. Do you think this is a bad idea?
Old 11-03-2012, 11:41 AM
Gary Lewis's Avatar
Quote:
No, I've not done black paint jobs before. But, I've always been told black shows everything. IIRC Chevy didn't supply the 'Vette in black for several years because they couldn't get the fiberglass smooth/straight enough to not show the waves.
I don't think it is a bad idea to go with black on your truck, although if it is subject to getting banged a bit you will be able to see the damage. You'll just have to be more careful with black than other colors.
Old 11-04-2012, 07:37 PM
truckertrav truckertrav is offline
truckertrav is gaining momentum as a positive member of FTE.truckertrav is gaining momentum as a positive member of FTE.
I voted LOW because I have checked MANY places(body shops and individuals)..
My 85 doesn't have any rust,dents,etc..
Only the tailgate,by the handle has small dent..
The cheapest estimate I got(with me pulling bumpers,mirrors,grille,emblems,lights, etc. was 1700.
That is for 1 color, not two-tone...
If I could have got a decent job for that much work as yours has to do, I would jump all over it.....IF....The guy truly does good work..
Old 11-04-2012, 07:46 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I wouldn't let on that you are in no hurry to get it done, tell him you expect to pick it on a certain day so he doesnt put it off until you have to hound him.
Short bed body work BigBody 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-27-2011 10:33 PM
Body rust Uncle Ethan 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-04-2010 09:11 AM
1997 F-350 460 Towing Mods Update Dezertracer 1987 - 1996 F150 & Larger F-Series Trucks 5 03-08-2010 09:55 PM
"New" Truck, New Member Marvinmycat 1987 - 1996 F150 & Larger F-Series Trucks 15 03-27-2006 05:22 PM
3" Body Lift on a '77...How hard is it???? ripoil 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-01-2004 09:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
