1994 F350 with Dana 60, how many shaft seals?
Hi,
It's been a while but I'm back. I have a 1994 F-350 (460 BB) with what seems to be a Dana 60 up front. It started to leak fluid on the passenger side shaft a while ago. Now it's so bad that if I park the rig for a few days it will drip and Wife is not to peachy about that. Just before I go ahead and dig in, how many shaft seals does the D60 have per shaft and would I need any special tools (from Lisle, OEM, etc. or homemade) to replace and install the seals?
Thanks!!
Coolones
Thanks!!
Coolones
Thanks for the replies!!
So, my luck, it's the longer side... I suppose that a long threaded bar with a makeshift slide hammer on one end and someone else to either spot or hammer would do the job? Is there any thing I should be careful with? Would I have to do anything with the shim and backlash stuff or just putting all back in place as was is ok?
Knewstroke97
11-28-2014 07:43 AM
philipwhite
01-28-2006 03:59 PM
sharker98
12-21-2003 09:16 PM
