2004 F250 6.0 EGR cooler failure
Old 11-01-2012, 09:46 PM
kelleyboy's Avatar
kelleyboy
kelleyboy is offline
Unhappy 2004 F250 6.0 EGR cooler failure
My truck has 111,000 mi. and suffering from the second EGR cooler failure. Is the Bullet
Truck has 111,ooo mi. and plagued with the second EGR cooler failure. Question: Is the Bullet Proof products as good as they advertise?? What path should I take, sell or fix and how much can I expect to spend if I decide to get repairs made?
Old 11-01-2012, 09:59 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
have you been changing the oil cooler too???
Old 11-01-2012, 10:18 PM
kelleyboy's Avatar
kelleyboy
EGR cooler failure
The first EGR cooler failure was covered under warranty at 55,000 mi. I assume Ford products were used but not replacement of oil cooler. Now 55,000 miles later another failure, and my question is can I find quality products to repair this vehicle or should I sell this truck and not look back.
Old 11-01-2012, 10:23 PM
BLADE35's Avatar
BLADE35
the ROOT PROBLEM is the OIL COOLER so replace it too
the Oil Cooler Plugs and starves the egr cooler for coolant at this point EGR Cooler burns up
also install a coolant filter
do a thuro coolant flush to
then you will be good
If you dont replace the oil cooler the egr coolers will keep failing
Old 11-01-2012, 10:24 PM
BLADE35's Avatar
BLADE35
Old 11-01-2012, 10:30 PM
BLADE35's Avatar
BLADE35
you also need to get a gauge and watch ECT vs EOT no more than 15* spread
there are a few rules to taking the temps at the right time so get a gauge and Study up that link above
welcome to FTE
your truck will be fine it just needs to be fixed right
How do you know it the EGR Cooler and not an Injector issue???
you are probably corect to assume a EGR Cooler problem from the sounds of how the repairs went down I just want to be shure I send you down the right path
So are you losing Coolant and white smoke???????
Old 11-02-2012, 06:41 AM
kelleyboy's Avatar
kelleyboy
yes losing coolant, smoking, liquid out exhaust. Truck does not use oil, seems to be very solid except for above listed issues. Thanks for your help.
Old 11-02-2012, 07:08 AM
bismic's Avatar
bismic
bismic is online now
Received 2,460 Likes on 1,702 Posts
Do you know if your EGR cooler is the one with fins or tubes for internal components?
Old 11-03-2012, 08:32 AM
kelleyboy's Avatar
kelleyboy
Which oil cooler should I go with: reluctant to buy Ford,,is there an aftermarket oil cooler that you would recommend? How about EGR delete?
Old 11-03-2012, 01:52 PM
BLADE35's Avatar
BLADE35
Keep in mind these Oil Cooler Fail 2 diffrent ways.
1. Plugged Coolant Paths in Oil Cooler
2. A Manufacture assembly issue/Internal Breach what mixes Both Coolant & Oil together
once you clean the cooling system and get a coolant filter the OEM Oil Coolers been fine
I Plugged a OEM oil Cooler 1.5years ago in mine I flushed Very well and Ran a coolant filter for a couple months before I changed the OEM Oil Cooler I have around 15K since and My Delatas are still Good
I also run ELC thats Silicate Free it seams to help the Coolant filters Go Longer
There is Some Debate that the OEM Gold Coolant causes the Issues with plugged oil coolers I Cant say it Does or Does Not However my coolant filters do Last longer FWIW
Also Keep in mind By Deleating the EGR Cooler shure you eliminate that part BUT you still must watch the temps for the Oil Cooler
I did go a EGR Deleate on mine But Not for any reasons mentioned here or because of the issues you Have Now
However if you want to spend some money there are other options
Here is the one I kinda like its from IPR its a OEM Oil Cooler relocation kit and Inline filter it willl filter at 100% of the coolant going to the Oil Cooler. Its $$ 1300.00
IPR External Oil Cooler Kit for Ford 6.0 Powerstroke
Here is the BPD option its a total removal of the OEM Oil Cooler and then uses a air to oil cooler up in front of the truck. It removes the Risk of the either of the two ways these oil coolers fail. However its the most money around $$ 2200.00
BulletProof Engine Oil Systems
Old 11-03-2012, 02:41 PM
BLADE35's Avatar
BLADE35
I know Alot of this^^^ was on Oil Coolers but you must address the ROOT Cause of the EGR Cooler failure
Also might be worth finding a shop that little better with 6.0L
Old 05-29-2014, 06:36 PM
Harrier and Ford guy's Avatar
Harrier and Ford guy is offline
oil cooler failure / coolant flush
Need some advise. Have gray milk shake consistency fluid in the coolant tank of my 2004 6.0. I am assuming a oil cooler failure. (Made it to 100,000 miles before it failed). If so how do you clean the cooling system as if you do it with the old cooler installed would it not continue to leak oil into the coolant? If I do it after I repair it, will I not contaminate the new cooler or if I put a after market cooler on it, will I not contaminate the new EGR cooler?
imcqueen
11-16-2017 04:50 PM
Grant-Dieseltech
11-22-2014 12:05 PM
MC5C
03-23-2013 12:34 PM
2006powerstroke90
01-18-2012 06:19 AM
046.0PSD
01-07-2010 02:17 PM
Quick Reply: 2004 F250 6.0 EGR cooler failure
