Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 11-01-2012, 08:21 PM
sburnett1960 sburnett1960 is offline
Garage is empty, add now
sburnett1960 is starting off with a positive reputation.
4.6 in my box
I just scored a nice '60 F 100 and was thinking I'd drop the 4.6 out of my '95 Lincoln in it along with the automatic... I'm leaning toward a front k member out of an '03 and up Crown Vic but I was wondering about the wiring and what needs to leave the Lincoln and come along with the power train? Anyone familiar with this type of swap?
  #2 (permalink)
Old 11-02-2012, 03:25 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Lots of those swaps have been done. I'm sure if you search around the forums a little you can find some build threads.
  #3 (permalink)
Old 11-02-2012, 07:29 AM
fun-ford's Avatar
fun-ford fun-ford is offline
1960 Ford F-250
My Garage
fun-ford is starting off with a positive reputation.
kevin Ingle
Try to get the whole car,the more you can use the better.
I used motor ,trans,radiator,ac compressor etc,in my 53.
I bought a wiring harness from The Detail Zone.
You can use the lincoln harness if you have the patience.
I am planning to do the same thing to my 60 crew cab.
I have the 04 front end ,and I am looking for a wrecked 1999-2004 Crown Vic donor.
  #4 (permalink)
Old 11-05-2012, 06:51 AM
1959_f100's Avatar
1959_f100 1959_f100 is offline
1959_f100 is starting off with a positive reputation.
does any one know if a 03-04 mercury marauder front end is any different than the crown vics. im planning on putting a 4.6 in mine but id like to use the 4v out of the marauder.
  #5 (permalink)
Old 11-05-2012, 08:40 AM
THartman THartman is offline
THartman is starting off with a positive reputation.
The Marauder IFS is essentially the same. I don't recall which model of the Crown Vic had the same springs on the front as the Marauder.
  #6 (permalink)
Old 11-05-2012, 09:05 AM
I actually have a complete '95 Lincoln town car and its really a pretty descent old car... and the motor has less than 5000 miles on it since it was replaced...
Wish it had the newer stile k member front suspension but I plan to use the entire drive train in my truck... I had wondered if I could use the wiring harness but I wasn't sure about how compatible it would be with switches, gauges, etc....
  #7 (permalink)
Old 11-05-2012, 12:46 PM
1959_f100's Avatar
does any one know how wide the crown vic suspention is.
  #8 (permalink)
Old 11-05-2012, 05:36 PM
Do you want hub to hub or where the IFS bolts to the frame? The width where it bolts to the frame is ~ the same as our frame.
  #9 (permalink)
Old 11-05-2012, 06:02 PM
1959_f100's Avatar
hub to hub
  #10 (permalink)
Old 11-06-2012, 01:15 PM
Here is what I have:
Track width with stock wheels - 63 1/2
Hub to hub surface - 67 1/2
Outside of tire - 71 1/4
  #11 (permalink)
Old 11-08-2012, 08:24 AM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
2losteve 2losteve 2losteve
Quote:
What fun-ford said - 'if you have the patience'. I've read where some guys have gone through the whole harness and eliminated everything that's not needed for their application. Modular V8 and V10 Conversions and Swaps is a website that has a lot of good info, also try Fuel Injection Technical Library » Home.
I've got a '57 that I plan on putting my '95 Mark VIII in also but haven't started yet.
Steve
__________________
'56 F-100
'57 F-100
'54 Chev sedan del
'71 C-10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
