Clutch pedal bypass
Clutch pedal bypass
Doing a remote start on a 2002 f350 diesel and need to bypass the clutch switch in order to remote start the vehicle. I have a 6 pin plug at the switch and I am having a hard time figuring out which wires need to see what. Has anyone done this before or have any input.
Pin layout on AllData
pin 1 (LB/YE) voltage supplied in start
pin 2 (TN/RD) switched power to starter motor
pin 3 (TN/LB) speed control, deactivator switch
pin 4 (RD/LG) voltage supplied in run and start
pin 5 (WH/PK) voltage supplied in start
pin 6 (LB/YE) clutch pedal position switch to PCM
lol had a feeling I would get that response, and yes it can be dangerous but the company I work for has a disclaimer for that and as the installer I can't really say no. There are a few safety features used to help ensure the vehicle isn't started while in gear but at the end of the day it is still possible. None the less I figured it out thank you anyway.
Used a relay on pin 2, (rests at 4v and jumps to 12v while clutch is depressed) used a 12v output on the remote start to trigger the relay for a 12v output to the clutch pedal and that did the trick.
