November BS Time
#61
#62
#63
#64
#67
Received 3,546 Likes
on
#68
hi crash how's it going?
no running lights from factory? that's pretty weird.
happy thanksgiving everyone.
#70
#71
Dana 44 front Dana 60 rear axle 4x4 rock crawler swamper 4.10 gear 35" | eBay
It's really not that hard to swap out the ring and pinion. The real deal is the
preload and shims.
Sean
preload and shims.
Sean
#72
#74
4.10's were factory for some f250's (camper special, trailer special) and most f350's in the 70's. Like stromburg said, your crusing rpms will be in the upper 2k range. Mine turns 2600 with a c6 and 4.10 axle, with 31's.
If ever you think 4.10's and 35's, look at one of my friends; he has 4.88's and 35's in a 4 liter jeep cherokee
Hope you all had a wonderful thanksgiving
Jameson
Jameson
#75
on
If it was me I would stay away from the closed knuckle axle like in the ebay add that Yahiko posted. If you are going to swap axles get an open knuckle axle I think they quite making the closed knuckle in the early 70s.
I plan on swapping axles in my Bronco this winter. I have a set of full width axles, Dana 44 with disc brakes and a Ford 9" that I need to re-gear to 4.10s first. I hope I can get it done this winter, I didn't even look at them last winter.
