Gauges
Gauges
Hi I would like to have some way to monitor my 6.4 and to tell what is going on.
Now I do NOT want a turner as I still have my esp extended warranty so I do
not want to void it!! I have look at scan-gauge and bully dog, but I wonder
what some of you with out turners are doing. Thanks
I use the EDGE CTS gauge only, I did not want the tuner either for the same reasons as you but it allows me to monitor my temps and other info. Since mine was a 2008 I also use the EDGE as my back up camera since that was not available on my truck.
I am very pleased with it, I know others on here use it as well. I picked mine up at autoanything . com.
Leon
Leon
One big advantage of a scangauge is it's easy to see if your eyes are going like mine.
The Bullydog is essentially the same as a H&S. It's as big as a business card. Your eyes will likely tend to focus on the numbers on the left column more than the analog gauge.
For serious logging and troubleshooting, I use an AutoEnginuity scanner.
It plugs right into the OBDII port. You will have to plug the Edge into a computer initially to register and DL the backgrounds and check for updates. After that mount your pod (after you paint it). That mounts with double faced velcro that doesn't move! Painting the pod, go to O'Reilly;s or which ever auto parts store carries Dupli-Color Perfect Match paint. The gray that matches the 0'8-'10 Lariat interiors is BFM0225 Medium Charcoal Met(1B) for Ford Original colors.
After painting and mounting pod, pull weather stripping loose at dash on driver's side and remove the side panel. Route wiring behind that panel down to OBDII port and plug in. Put panel back, push weather stripping back into place. Turn on truck and set up guages the way you like them.
another plus for the edge is that it will alarm and let you know when the truck goes into exhaust cleaning. You might miss the truck messagfe but you won't miss the edge. In fact, I think it stays on until the cleaning is complete. At least that's what mine did when I used it for monitor only. Mine is an older racing evolution model so it may not be the same as the newer CTS. How about it guys, does the CTS work the same?
On the CTS you can set up one of you parameters to show when it is in regen or it also has a Red "R" that appears on the top of the screen the whole time it is in Regen mode.
Leon
Yes, it does. However, the entire background on the screen used to turn black when it was in regen which made it hard to miss. After my last update(has one now that I haven't done yet) there is just a White 'R' inside a Red circle that comes on to notify you of the regen status. This one is a little easier to miss than before. Need to update again to see if anything changes now.
Now in the interest of being fully informed here's one more thing you should know. If you think that sometime down the road you might want to delete the DPF then you must find an Edge Racing Evolution. Key word is racing, if it isn't a racing model you can't use it to delete. The bad news on that is that they quit making those about 6 months or so back. There are still some around at the speed shops, you just have to look hard. If you don't think you will ever delete than it doesn't matter except posssibly for resale value.
