R & R clutch on a T98
I think my clutch is finally gone - got about an inch of pedal before it engages. Going to try adjusting the linkage from the slave cylinder to get a little more, but I think it's about gone. Anyone have any helpful tips (pics would be great!) for changing out the clutch? Also found that there is a 10", 11", or 12" available; which should I go with? It seems from a little research that the 11" is probably what I currently have, but would the 12" be an upgrade? Thanks!!
I know that the 10" and 11" have different flywheel and pressure plate sizes so I am sure that the 12" does as well. A t98 should have had the 11" from the factory. Unless you are upgrading the flywheel too, better stick with the 11".
Edit: For all I can tell the 12" only came in f-350 - f-950's with 302 and up v-8's. the 262 came with up to an 11.5". I don't even see a 272 or 292 with the 12" clutch.
Good idea, thanks!! Went ahead & replaced the slave cylinder & adjusted the linkage yesterday, but ran out of daylight before I could enlist some help to get it bled. Maybe I'll get lucky & that'll fix it. Have to wait a couple days for the weather to improve to find out, though.
Update
New slave cylinder didn't help, so I went ahead & tore into it. Got the starter out & look at this *****: HUGE rats nest in my bellhousing!
Some pics with the trans pulled:
[URL=http://s1107.photobucket.com/user/Byrd_Dog/media/RMBiPhonepics024_zpsc313b646.jpg.html]
Have to say that removable panel over trans is handy as hell!! 4 bolts hold the trans on the bellhousing, & once they're out, trans just slides right out.
This times a bazillion. You're there, get a clutch kit and be done with it for another 100K miles (5 miles if you ride the clutch). If it were me, and I'd already done the slave, I'd get a rebuild kit for the master or even replace it if needed. The master isn't subject to things like water, salt spray ( and rats!). So it may be OK. but there's the piece of mind thang that comes into play
Makes me wonder if I'm likely to run into difficulties getting the right clutch if I get a T5
mustang_gt_350
04-15-2016 06:40 AM
HKH_6
12-11-2002 06:41 PM
