I HAVE NO BRAKES!!!!! :(
Thank you VERY much for opening my thread.
Ok, now HERE'S is my problem. Joe350 and I replaced my tie rods and ball joints four months ago in my 94 F350 4x4 IDI w Turbo and 5spd man at 200K miles. We unfortunately over torqued the drivers side barring in her Dana 60 front axle. Because of this, the other day while driving down the road, my drivers side wheel FELL OFF while driving
The spindle, hub, all 8 studds, and caliper were ALL damaged. AND at this time, I lost ALL of my brakes!!!!!!!!!!!
Thank goodness I have a Man Tranny and E brake
So, since then, Joe350 has replaced ALL the damaged spindle, hub, studds, and 2 piston caliper with new ones!
But here's the problem. The brake pedal is STILL soft and goes ALL THE WAY to the floor!!!!!!!
we bleed the HECK out of the two front breaks MANY times, but still no progress.
What are youre guy's thoughts?
if your gonna bleed brakes you cant just bleed the front ones you have to bleed all four and you have to start with the furthest away one so the back passenger then the back driver then the front passenger and then the front passenger. also one thing to note is that if your still on your stock master cylinder and it caught and air pocket you very well could have broke seals that might be something to check also other than that just keep pumping
If you have access to a compressor, this will make bleeding/flushing your system very easy:
Brake Fluid Bleeder
That stupid little gizmo has been a lifesaver for me and is especially handy for bleeding systems where it just seems like you can never get the last bit of air out.
Mike
Brake Fluid Bleeder
Mike
Received 3,107 Likes
on
i once had an inner bearing fail, and the wheel stayed on, but i lost all of my brakes. even like yours, everything was trashed. but mine was caused by water in the bearings, not being overtightened.
mikey, i've only lost my vacuum pump 3 times since i've had my van. i wouldn't understand oh, plus the time i lost the belt, make that 4 times. first test is to pull something off the vacuum tree and see if it sucks or not
i would bleed it. if that doesnt fix it, then i would say its the sensor. im not sure where its at but i would guess its that and if you cant find the part for it and or dont wnt to pay the money for it pull the light bulb out. who needs abs anyways! im not even sure if they worked all that well. i havent had a truck that new before i ususally stuck with the 80's models
An update:
Well, we got the Brake Bleeder tool. Its a pretty cool device. Weve bleed all four brakes with it like 1000x's but STILL the infamous Sinking Pedal
The ABS light is on now. So our theory is that the ABS needs to be bleed. Ive done my research but I can NOT find how to bleed it.
Anyone know how?
Thank you in advance
Anyone know how?
