Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 11-01-2012, 09:33 AM
BuickBrian's Avatar
BuickBrian BuickBrian is offline
Garage is empty, add now
BuickBrian is starting off with a positive reputation.
WTB 80-96 F150-F350 4x4 rear sway bar brackets
Need a pair of the rear sway bar brackets that came attached to the bottom of the frame on the 80-96 F150, F250 and F350 4x4 trucks. 2-wheel drive trucks did not have them. Some trucks had them bolted on, some riveted. One rivet/bolt goes through on the side of the frame, and two go in vertically on the bottom of the frame rail.
  #2 (permalink)
Old 11-15-2012, 04:39 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.
Still looking for these?
I have a set on one of my parts trucks, but they may be too rusty for you, it was a plow truck so had some pretty bad rot in places (body is shot and the frame looks like swiss cheese in some places).
__________________
1988 F250, 7.3L IDI, regular cab, long bed, 5spd ZF
Mods: ATS turbo, 3.5 inch exhaust, superduty springs front and rear, 4 gauge A-pillar pod: boost, pyro, coolant and 4th spot is switches; was 2wd, now 4wd with Dana 60 front axle
next projects: fix/complete the 3.5 inch exhaust (tailpipe exits waaaaaay to low, and needs to be extended out from under the bed) swap to a rust free cab
  #3 (permalink)
Old 11-15-2012, 08:36 PM
BuickBrian's Avatar
Yes! Still looking for a pair. Long as they are solid enough for me to sandblast and paint they will work. Are yours bolted or riveted on?
  #4 (permalink)
Old 11-15-2012, 09:32 PM
fordka's Avatar
fordka fordka is offline
fordka is starting off with a positive reputation.
what yr trucks you got. im looking for 1 aluminum rim with like little rivets on the outside for f150.
  #5 (permalink)
Old 11-17-2012, 11:15 PM
I think it was riveted on. I'll have to take a closer look to see if they're solid enough. Maybe I'll pull that truck forward and get a picture, not sure if I'll have time in the next couple days, I should, but I'll forget.
Fordka, sorry no aluminum rims, and no F150's
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
