Bolt torque specs - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Bolt torque specs
Old 11-01-2012, 10:31 AM
damonlan damonlan is offline
damonlan is starting off with a positive reputation.
Bolt torque specs
Can any one point me to a source for bolt torque specs for my 2003 F-350 7.3L PSD DRW Lariat? I have an imediate need to specs on the Panhard and sway bar bolt torque specs, but would like all why I am at it.
Thanks in advance.
Old 11-01-2012, 05:12 PM
danskool's Avatar
danskool danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
Not sure what you are calling "panhard"
But does this help ? 4 x 2 Front.
Old 11-01-2012, 05:34 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
Get it tight then use a big piece of pipe on the end of the wrench and give it another 1/4 -1/2 turn and you should be good
Old 11-01-2012, 07:42 PM
roger on the 80lb-ft for the sway.
Just to be sure on the drivers side Panhard Bar Bolt
1/4 to 1/2 past sounds a little iffy to me, especially for a guy that tend to break bolts. Any suggestions on actual torque?
Old 11-01-2012, 09:06 PM
danskool's Avatar
Go Bills !
ah, 4 x 4 front.
Track bar = Panhard?
Same spec, Both ends
Old 11-01-2012, 09:12 PM
danskool's Avatar
Go Bills !
4 x 4 front sway.
All appear to be the same as 4 x 2
Old 11-02-2012, 09:05 AM
Bolt Torque information
Thanks danskool. God bless ya.
Incidentally, where can I get a copy of the media you got that information from?
Thanks again.
Old 11-02-2012, 09:17 AM
1fixitman's Avatar
1fixitman 1fixitman is offline
1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.
Subscribing for the information location.
Old 11-02-2012, 05:37 PM
danskool's Avatar
Go Bills !
It came off a cd i bought years ago on Ebay. No Wait, That was my Jeeps wrangler.
Something like this, I can not locate the exact thing it was a long time ago. http://www.autorepairmanuals.biz/sit.../FCS1255100CT1
What sucks about mine is that it is old.. 2003.. I want to look for a new better one and if someone has one, Please post it. Mine is terrible to find stuff, most times it is quicker to just search online or use autozone, It is scratched from the dog and i am about to toss it out the window because it don't work all the time and don't work with my 64bit vista.
Old 11-02-2012, 06:09 PM
danskool's Avatar
Go Bills !
Or wonder how this one is. It is cheap enough. Now i got my self looking for a new one. Wonder if they have my focus too. Ford F Super Duty 250 550 Service Repair Manual 2000 2001 2002 2003 DVD CD | eBay
Old 11-06-2012, 06:39 PM
danskool's Avatar
Go Bills !
Just received in my cd from above link. Post 10 for $12.. Same thing i have and you can see the type of illustrations it offers, above.. .. Sweet.
The cd i had was scratched and abused and locked up on occasion. Glad i got the same thing because i know my way around it.
I bookmarked that seller.. Will be buying from again.
I also received in one for my Focus..
Old 12-29-2012, 12:21 PM
jcrammell's Avatar
jcrammell jcrammell is offline
jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.
Quote:
Originally Posted by danskool View Post
ah, 4 x 4 front.
Attachment 63685
Danskool, How are you supposed to get 406 ft lbs of torque? My torque wrench only goes up to 150 ft lbs.
Old 12-29-2012, 01:24 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Quote:
Get this guy to help and cut the 150 ft lb wrench to about 1/3 its length?
Old 12-29-2012, 01:27 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
I always like to refer to a general bolt spec chart, [dia,tpi,grade,lubed or not lubed threads]. to compare, sometimes there can be a misprint which can lead to broken bolts or things falling apart.
Old 12-29-2012, 01:36 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Jody, you have to buy a torque wrench someplace other than Harbor Freight.
Torque specs, flywheel and pressure plate bolts cadunkle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 11-19-2016 07:59 PM
Trans pan bolt torqu spec. neilc88 Modular V10 (6.8l) 10 05-31-2013 10:13 AM
Fan to fan clutch bolts torque specs? cutlass 1999 - 2003 7.3L Power Stroke Diesel 6 07-15-2012 12:16 PM
torque specs. gbeach Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 05-20-2011 02:44 PM
Torque spec for tensioner rblaine9000 1999 - 2003 7.3L Power Stroke Diesel 1 12-13-2010 02:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
