November chat and general BS thread. All are welcome
#76
#77
#78
#79
Oh I have more than one set...9 3/4 wide is the norm. Once I am back home we can work out a trade of some kind. I'll trade a hand working on a project......
I have a set of slotted mags too, that are a little narrower.
Morning folks.
Morning folks.
#81
#82
RC. The problem I thought I'd have is the shifter handle length. Since it's in a '50's truck, the seat position is kinda high for a car shifter. I thought I could build a Lokar style shifter with a longer handle. A simple detent style shifter with a long handle is all this guy would need. Like I said, I have a complete B&M shifter with a cable and brackets, I'm just wondering how easy it will be to operate in the truck. I don't want this guy to have to lean over to the floor to shift it. I'll know more in a couple hours. Thanks for the offer, though.
Jeff. Do you have an extra set of those? My friend is building a General Lee and needs a set.
#83
alan i just went out and looked at the 3spd auto shifter i have.. it is kinnda short to fit in a transam.. i guess it could be modified to be made longer the shifter handle is straight it is a hollow tube with the reverse lockout running thru it.. may be just as easy to build one from scratch i guess.. if you want to look at it let me know..i could make a trip your way and get some tires changed around so would not be a complete wasted trip anyway
#84
#85
#86
Alan, why not build a box to raise the shifter and just use a factory made one wo you don't have to get the math right on the lever lengths?
Good morning everybody, had a busy weekend of not working on my own stuff. 86 Ranger with an overheating problem...cracked thermostat housing. 2002 Mitsubishi Montero I've diagnosed a possible junk ignition control module. I could find no broken wires so it almost has to be that or a bad PCM/ECM...yuck.
#88
Chip, the thought had crossed my mind about the shifter. I just got the drive shaft built and in and the hole for the four speed shifter welded up. I still have to hook up the trans cooler lines, detent cable, dipstick tube and replace the filter. The shifter is last on my list. I have some tubing here I could make a pedestal mount for the shifter, too. After I get it all back together, I'll see what I need to do about the shifter.
#89
#90
