1992 F150 302 & Mustang 302 - Ford Truck Enthusiasts Forums
Old 10-31-2012, 01:14 PM
ErikFlareside ErikFlareside is offline
ErikFlareside is starting off with a positive reputation.
Talking 1992 F150 302 & Mustang 302
I'm just wondering what the differences are from the F150 302 and the mustang 302 are. I want to add more horsepower to my truck but a lot of the time i cant find engine parts for it, so I was hoping I could buy parts for the mustang to fit my truck.
Old 10-31-2012, 10:25 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Internally the only differences between the HO and truck motors are the cam and pistons, the HO cam has more lift and duration and the HO pistons are forged vs cast but compression ratio is the same for both. Externally the truck intake is WAY bigger than the HO so it's not a bottleneck at all, but the truck exhaust is a big one. More HP from a truck motor is dumb easy.. swap in a better cam and change the whole exhaust system.. BAM... you got 260-275hp. But it's still a mouse motor pushing a vehicle that is on average 1000-1500lbs heavier than a mustang so don't expect Mustang performance.. that takes 50 to 100 more cubes or a supercharger and lots more axle gearing.
Old 11-01-2012, 12:33 PM
Thanks man, you got any ideas on some better cams i could swap in?
Old 11-01-2012, 06:32 PM
Conanski's Avatar
Yep. How is your truck equipped.. gearing, trans, tire size, and how do you use it?
Old 11-01-2012, 07:48 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
92 has the "base" roller cam in it, so anything you swap in there is an improvement. For starters even a 94-97 302 truck cam is a vast improvement, although you'll need to deal with the different firing order for this one or the HO cam. I just sold a 92 awhile back and it had an E4OD/3.55 rear, it was every bit as responsive as the 95 I have now with a 351/E4OD/3.08 rear.
Old 11-02-2012, 09:55 AM
Everything is stock in it. I have 29 inch radials with 15 inch rims. I'm just using to go back and forth from school. I'm planning on having a 6" suspension lift and 2" body lift with 37" tires. Its a 4x4
Old 11-02-2012, 03:42 PM
Conanski's Avatar
Unfortunately there were at least 6 different transmissions used in these trucks and 5 potential gear ratios were available so "stock" doesn't tell me anything you'll need to find out what you have and post it up, but that's easy enough to do just find the trans and axle codes on the drivers door calibration decal.
The reason that's important is because some of the transmission don't have an OD ratio and those that do vary a lot and that will impact the gear ratio you're going to need for 37" tires.. which is gonna range anywhere from 4.10 to 5.13.
Old 11-02-2012, 07:36 PM
Check the axle ID tag on the back of the rearend, you'll find the ratio there and whether it's got traction loc too. I'll bet it's got 3.55's, if so it'll have 3 55 stamped there, if it's got trac-loc, it'll have 3L55. And for a truck, you want to move towards more torque output, not HP, especially with a 302 turning larger diameter tires.
Old 11-06-2012, 06:18 AM
A1C DiMaggio's Avatar
A1C DiMaggio A1C DiMaggio is offline
A1C DiMaggio is starting off with a positive reputation.
if you want all out power, andersonfordmotorsports.com has arguably some of the best cams in the business, but they are more pointed toward HP. also a comp cams magnum 270hr is a good replacement for the stock cam, it responds well to mild mods like exhaust and intake and it has a pretty smooth idle
Explorer/Mustang 5.0 in F150 with larger 11" Flywheel anyone ? waid302 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 13 09-10-2014 03:31 AM
48-51 F1 Mustang II Suspension Help Please??? gt40racing 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 11-28-2011 11:43 PM
86 mustang 302 into a 94 f150 with 302 my93 1987 - 1996 F150 & Larger F-Series Trucks 8 12-30-2010 11:50 PM
Mustang Mass Air for 95 F-150? MrNord Performance & General Engine Building 33 11-08-2010 08:33 PM
i have a f150 with a 302 i wanna turbocharge it njredneck Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 7 02-15-2010 05:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
