F250 Tranny-E4OD
F250 Tranny-E4OD
Newbie to the forum!
I own a 92 F250 with a 460 v8 LB, SC 2wd, AT with 4.10 gears. It has 141,000 miles on it and the tranny is acting. I am the second owner on the truck since last year and primarily use it for towing a car trailer.
Lately it has been clunking and not shifting correctly. The PO hauled their 5th wheel RV back and forth across the U.S. between Nevada and MN every year, so its all highway trailering miles.
Is the E4OD the standard tranny in this truck, if not what is? What are my options for replacing this tranny - could i use an AOD? Looking for help!
Thanx!
Mike
64 Ford Falcon Futura Convertible SROD
66 Ford Mustang Coupe
48 Ford F1 PU
51 Ford F! PU
92 Ford F250 PU
Thanx!
Mike
48 Ford F1 PU
51 Ford F! PU
92 Ford F250 PU
on
E4od would be the original trans. Aod is lighter duty, I dont think they made one for a big block. The E4od is all electronically controlled, you may just have a sensor going bad or something simple. Check for codes in the computer before condemning the trans. Oldfuelinjection.com will show you how to get codes without a scanner.
kaufmanlawn
03-16-2006 04:49 AM
javi2001
08-20-2003 06:01 PM
