Few items on the new truck
Old 12-19-2012, 11:12 AM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
Ok guys, when I bought the truck last week I was completely aware of what I thought to be oil in the coolant. Oil cooler Orings, no problem. Brought it to a local shop that does a LOT of work on power strokes, and happens to be married to one of the women at work, so i know he isn't trying to screw me.
He just called and here is his opinion: the oil cooler looks fine on the outside, and from looking into the coolant, there's definitely a residue, but may be fuel and not oil. Wanted me to know that the oil cooler Orings may not infact fix anything, if the problem was fuel. He said fuel in the coolant is likely a cracked injector cup (which makes since from my knowlege).
He also said the passenger oil line was leaking where the strap had rubbed, and that he checked the ICP and there was oil in it, so he recommended changing that. Other than that, he didn't see anything else that concerned him.
How about some thoughts and opinions? I told him to go ahead with the oil cooler Orings anyway. And I'll replace the fuel line and ICP when I do my RR order soon.
Sound like injector cups to you all?
Old 12-19-2012, 11:23 AM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
Here's the best pic I could get for the degas bottle.
Old 12-19-2012, 11:46 AM
JT250's Avatar
JT250
JT250 is offline
If it is fuel in the coolant then yes injector cup. I did the cups on mine and it wasn't too bad as long as the puller you get actually works. I tried 2using different ones before I ended up making my own. The ones I tried were Loaner tools and the person presenting that loans them has since fixed the problem. You just have to make sure you get the loctite on the right places and the right amount. Otherwise it is just time.
Old 12-19-2012, 12:02 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
What he said^^^ Buddy of mine has his in for the same thing right now. Looked kinda like yours.... black from the outside.
Old 12-19-2012, 12:17 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Do a smell test to see if it's fuel or oil. You can smell the fuel. I wouldn't mess with the oil cooler if it isn't leaking.
Old 12-19-2012, 12:39 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
If its a high mileage truck I would do both oil cooler R&R,and inj. cups..since you know you have one or the other in your coolant,if you do one and miss there goes another 4 gallons of coolant..jmho
Old 12-19-2012, 01:03 PM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
He's doing the oil cooler, and I'll head to the south Texas tech day for the injector cups if its still leaking into the coolant. I'll kill 10 birds with one stone that way.
jr2000sd
15
10-26-2017 06:02 PM
Faster71
17
02-19-2014 07:44 PM
bohinny
12-07-2011 10:52 PM
joeyd61
08-17-2011 12:00 PM
68Mercury250Ranger
11-09-2008 01:02 AM
Quick Reply: Few items on the new truck
