Head question.
According to this, some were the same heads. Probably most. Do you have casting numbers off the 352 heads? Remember, they will not have hardened seats, unless they've been fiddled with.
FE Cylinder Head I.D. and Application Chart
As long as your block is safe at .050 over--sometimes a question--and you get the crank, rods and the right pistons, you are good.
What else are you going to do?
Note there are several pistons available, some with 8ish compression, some in the 9s and some 10+, so you need to watch out for what you want. Most low end rebuild "kits" give you the low compression jobs.
rebelman108
03-19-2009 12:11 PM
tbm3fan
02-21-2009 08:13 PM
WillyB
07-24-2005 09:05 PM
scottie2hottie
11-03-2004 05:29 PM
Tom390
05-14-2003 06:25 PM
