Looking for Carb Replace/ Rebuild Kit - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 10-30-2012, 03:59 PM
ThreeColt ThreeColt is offline
ThreeColt is starting off with a positive reputation.
I picked up a 1961 F-250 late July and drove her 2,000 miles home over the Rockies and across the plains in 95 F heat. All went reasonably well given any number of getting to know you surprises. I was doing 10 - 15 mpg at about 60 mph. Idle could get rough and fall out after hours of hot running. Couple mornings it was hard to start after a day's work. So I am suspecting a leaky manifold gasket and the carb could use replace/ rebuild. This is the 223 cu 6 cyl with a 1bc carburetor. The only markings I can find on the carburetor are: 12 R 1958.
So can anyone help with the following questions:
  1. What is the carburetor on the F-250?
  2. What replacement carburetors can installed (and where can I find those)?
  3. Where can I get a rebuild kit for the existing carburetor?
Thanks so much for the help. I think it will make a difference.
Old 11-05-2012, 07:35 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
This is the 223 cu 6 cyl with a 1bc carburetor. The only markings I can find on the carburetor are: 12 R 1958. So can anyone help with the following questions:
  2. Where can I get a rebuild kit for the existing carburetor?
Welcome to FTE
1958/61 F100/600 223 I-6 used the same Holley 1V carburetor & carburetor kits.
C2AZ-9A586-B .. Carburetor Tune Up Kit / Obsolete
GREEN SALES CO. in Cincinnati OH has 44 = 800-543-4959.
C1AZ-9590-A .. Carburetor Master Overhaul Kit / Obsolete
GREEN SALES CO. has 5.
Old 11-05-2012, 11:06 AM
Thank you Bill. I cannot ask for a better answer than that. I told after the post that 12 R 1958 is only a casting number. In my wanderings I have also run into The Carburetor Shop.
Old 11-21-2012, 01:12 AM
Ianmattf100 Ianmattf100 is offline
Ianmattf100 is starting off with a positive reputation.
I am looking for a rebuild kit too for a single barrel on my 1963 f100 shortbed. Its the original carb for sure but I dont know what kind. Hres a pic..
Old 11-24-2012, 07:22 AM
Hey Matt, Tough to tell from the picture. That air filter is definitely not stock. Call The Carburetor Shop ((573) 392-7378). I did not try Green Sales (800 543 4959) per Number Dummy but no doubt they will get you the rebuild too. FYI, The Carburetor Shop did not have a replace, just the rebuild kit.
Old 02-20-2013, 08:18 PM
hotstuff hotstuff is offline
hotstuff is starting off with a positive reputation.
should be a model 1904 holley
Old 02-20-2013, 08:25 PM
the 1904 is for the 1961, the 1963 could be a ford f-1 model 1100 ,holley models 1940 or 1909
Old 03-26-2013, 01:45 AM
McMERC's Avatar
McMERC McMERC is offline
McMERC is starting off with a positive reputation.
i like the 223, my 63 merc longbed has one and after i got it home and tuned up i had to flush the fuel tank and replace the steel supply lines to the carb. i went to my local parts store and they hooked me up with a reman carb. i keep abot 80 to 85 kph(50-55mph) and get 23 to24 mpg. these little sixers have a nice sound and rythym at that speed (should check with a tach one day ).
the carb i put on was an autoline reman, i'll have to find the bill to get a part number, but these things are available and reasonably priced
1904 Carb Rebuild in My Future? jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 08-27-2016 09:00 AM
85 F150 Accelerator Cable - Odd KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 10-10-2015 12:41 PM
Carburetor Identification Troubles joamariel 1967 - 1972 F-100 & Larger F-Series Trucks 7 10-20-2014 01:29 AM
1966 F250 352 v8 Carburetor Shawnonthelawn 1961 - 1966 F-100 & Larger F-Series Trucks 8 12-21-2013 10:29 AM
please help id my carburetor radicimo Fuel Injection, Carburetion & Fuel System 7 08-04-2003 05:22 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
