01 F 350 5.4 gas motor change out.
Iv got a f-4350 with the gasoline 5.4 motor in it, and the number 8cylinder has lost compression and im pretty sure it's a burnt valve.
My question is I think Iv located a motor for a good price would it just be easier just to change out the motor and use the bad motor for parts?
Iv got a friend that has a shop with everything I would need like a engine puller.
I just really was wanting to know if it would be worth my time thanks
Easier is a relative term.
Here's some things you might consider:
How many miles on each engine?
What is the service history of the replacement engine?
Can you run and thoroughly test the replacement engine?
How much is the replacement engine vs. how much to have the one head rebuilt?
Are you sure it is a burnt valve? If so, what caused it?
Good luck either way you choose.
I bought the truck used so I'm not sure of the service history, it looks like it's been worked on before as all the seals look new and there's a helicoil in the number 8 cylinder the cheapest I found to have someone rebuild it is 700$ labor not counting seals and any parts that are bad or having the head rebuilt. Im not sure what caused the burnt valve ? And im not sure that's for sure what it is. It has lost all compression in the #8cyl it don't use oil or water and taking the valve cover off all the valves are moving right.
I found a replacement 5.4 same motor for 850 shipped
are you sure the helicoil isnt leaking? The previous owner must have ot of one any maintence on the truck for the plug to blow. And helicoil in a aluminum head Ford is ONLY a temp fix it will blow again. Id check and double check to be 100% sure the helicoil isnt the problem before i go any further
unless this previous owner NEVER changed the oil i cant see a mod motor blowing one valve out, especially when you say you can see them move freely when you removed the valve cover? i still say its the helicoil, maybe the mechanic cracked the head at the spark plug hole when he tried to install the helicoil in the first place? How did the truck run when you first bought it?
But now I know why they were selling it.
It looks to me like someone has had the motor apart before because most of the seals look brand new, but so does the timing chain and guides.
So I really don't know what happened
