91 explorer 4x4 A4LD to M5OD SWAP ISSUE
Hello all ,
finishing up a project for a good bud swappin out the A4LD boat anchor to the M5OD got all the parts exsept the trans from an identical mfg date ranger 4x4 alll the hardware installed clutch blead,fluids topped and all the odds and ends buttoned up hopped in to start the rig dash lights come on as per normal up AND ..........nuttin but a faint click from a little relay under the hood ...... after digging around a bit found the clutch switch out of place.....remidied that problem ........ hop back in and payin closer attention this time turned the key on and could not hear the feul pump precharge (normally quite audible).........step the clutch to the floor and the engine wants to crank in run position.......
In short: 1)the feul pump is getting no signal power from the ecm.....
2) and the engine wants to crank in "run" when ya push in the clutch?!?!?
The truck ran fine when it came in the garage now it dont wanna ..........real head scratcher on this one ......HELP!!!!!
tshelton
10-01-2007 01:16 AM
mkebullitt
10-15-2006 11:04 PM
chadbuddy34
03-23-2004 03:22 PM
