Firing Order
Firing Order
I found this information on another website... Is it accurate?
<table><tbody><tr><td>289</td><td>1-5-4-2-6-3-7-8</td></tr> <tr><td>302 (Pre-82)</td><td>1-5-4-2-6-3-7-8</td></tr> <tr><td>5.0</td><td>1-5-4-2-6-3-7-8</td></tr> <tr><td>5.0 HO</td><td>1-3-7-2-6-5-4-8</td></tr> <tr><td>5.0 Truck</td><td>1-5-4-2-6-3-7-8</td></tr> <tr><td>351</td><td>1-3-7-2-6-5-4-8</td></tr></tbody></table>
Assuming so, can anyone please confirm the HO never made it into a truck; at least not from 92 - 96... I pulled a short block from a F-150 of this era to replace the one from a 98 explorer. Need to confirm the firing orders are the same. If not the same, it is going to suck.
Is this article regarding the cam accurate?
Ford 302/351 W Roller Cam: Engine Builder
Its got me concerned that something might be different with the short block I grabbed if its a pre-94...
Depends on the cam installed in the motor. The 94-97 pickup and van 5.0's use the 13726548 order, as do the Explorer/Mountaineer 5.0's and the 94-97 roller 351's, all these engines used the same roller cam. This cam is slightly different from the HO roller, but uses the same firing order. The short block is the same between the 94-97 and the Explorer, with the only difference being that sometime around 97-98, the Explorer got different pistons. Not sure if this changed the comp ratio, but they are noticably different pistons from the earlier ones.
on
The actual HO motor was never installed in trucks but the '94+ version makes more power than the earlier motors so that's probably where people start thinking it's a HO, but as Baddad457 indicated it still doesn't have the HO cam or the forged pistons found in most HO motors. And all 5.0s from '94 on use the HO firing order so if the motor you pulled was older than that you may have a problem using it in the Explorer.
on
droppedf100
15
04-21-2023 06:23 AM
skid pan
05-15-2010 08:02 PM
pageparsley
11-25-2005 06:46 AM
