Alternator conversion supplier - Ford Truck Enthusiasts Forums
Old 10-29-2012, 08:05 PM
Talkwrench's Avatar
Talkwrench Talkwrench is offline
Talkwrench is starting off with a positive reputation.
Hi guys, anyone got any leads as to where I can get and alernator conversion kit for my ' 37 21 stud, the pulley, bracket and alternator altogether at a reasonable price. Need it sent to Australia though.. Is it cheaper to buy the parts seperate?
Old 10-29-2012, 08:41 PM
newold46's Avatar
newold46 newold46 is offline
newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.newold46 has a great reputation on FTE.
I bought my 6v alternator kit here. A very knowledgeable guy. I had pulley alignment problems with adapting the kit to a flathead 6, so I called him and he exchanged the pulley at no charge.
Old 10-29-2012, 08:48 PM
Talkwrench's Avatar
Thanks. Geez his alternator price is up there !
Old 10-29-2012, 08:59 PM
newold46's Avatar
True but not as bad as some that I've seen.
Old 10-30-2012, 10:16 AM
51504BAT's Avatar
51504BAT 51504BAT is offline
51504BAT has a good reputation on FTE.51504BAT has a good reputation on FTE.
Alternator
Try these guys.
Quality Power
<CITE>www.qualitypowerauto.com/</CITE>
<CITE></CITE>
<CITE>909-794-1600</CITE>
<CITE></CITE>
<CITE>Tim</CITE>
Old 11-01-2012, 01:29 AM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
Did Chris convert the truck to 12 volt, or leave it 6 volt?
Old 11-01-2012, 01:58 AM
Talkwrench's Avatar
12 volt gen but looks like its on its way out I couldnt get it charging. Think I would prefer an alternator.
Old 11-01-2012, 07:54 AM
newold46's Avatar
Did you try to "flash the field"? Assuming that you have a generator/regulator setup:
From the NAPA/Echlin "Manual for the Automotive Electrician", edition circa 1955:
Ford-Merc-Lincoln remove Field wire and touch to Batt wire momentarily; most other cars, touch jumper from Arm to Batt at regulator. For cutout 3-brush Fords, jumper between two terminals on cutout.
Just a thought. This is why I went to an alternator also.
Old 11-01-2012, 06:43 PM
Talkwrench's Avatar
I'll look into it... Also I see that you can oil the generator, any parcitular oil ..amount?
Quality power auto got back to me with a reasonable price for the Alt setup.
Old 11-07-2012, 10:41 PM
Talkwrench's Avatar
Ive gone with quailty power auto. Answered all my emails and the price was ok to get it to Australia. All up was about $305 AUD for the whole kit bracket and fan pulley too delivered . Just to by that alternator here [a chrome one pfft who wants that] is $299!. And I have to drive 3/4 hour there and 3/4 hour back just to get it.
I'll let you know how easy it is to fit etc.
Old 11-08-2012, 08:24 PM
51504BAT's Avatar
You shouldn't have any issues with Quality Power but the are just up the freeway from me if you have any issues.
Tim
Old 11-20-2012, 07:09 PM
Talkwrench's Avatar
New Alt
All has arrived , fitted no probs, must say they were a little rough when they fitted the pulley it was scratched on the inside I had to gently file it. Also quiet noisy.. Does the job..
Introduction - Australia Fanel 1973 - 1979 F-100 & Larger F-Series Trucks 19 01-10-2014 07:53 AM
1971 front end conversion gp 1967 - 1972 F-100 & Larger F-Series Trucks 2 08-16-2012 03:47 AM
56 parts in AUS DASCA 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 05-03-2011 09:51 PM
Alternative IFS for Ford Trucks Aussie 53 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 03-15-2008 10:08 AM
Australia Day farmtwuck International Region 1 01-25-2006 03:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
