Different Windshield Seals?
I'm in the process of ordering a weatherstripping kit for my "78" F250. I've noticed that JBG lists two different kits, one for 73-76 and one for 77-79. The only difference I see is the front and rear glass seals. My problem is, I'm not sure what year my cab is. I bought it by itself to replace the original cab. So my question is, are the seals THAT different that one seal can't be use in place of another? I really don't want to spend 200+ dollars in a seal kit and not be able to use 2 of the main seals. Here are the links to the kits:
1973-76 Pickup Super Weatherstrip Kit
77-79 Pickup Super Weatherstrip Kit
The difference in the windshield and rear window weatherstrip is the moulding or lack of moulding.
From '73-mid '77 the windshield and rear window either came with no moulding trim or the "wide" stainless steel moulding. Generally the lower trim levels came with no moulding, just the rubber gasket around the glass. You could also have moulding on the front and none on the rear and vise-versa. In mid 77 the moulding design was changed from the stainless to a narrow plastic strip. Again, the lower trim levels were more likely to have no trim.
There are three different gaskets, generally classed as 73-79 "no trim", 73-mid 77 "wide trim" and the mid 77-79 "narrow trim".
Different Windshield Weatherstrips!
1973/76 F100/350 / 1977 F100/350 before serial number O80,001.
D3TZ-1003110-F .. Windshield Weatherstrip-Use without Windshield Reveal Mouldings.
1973/79 F100/350 / 1978/79 Bronco.
D7TZ-1003110-B .. Windshield Weatherstrip-Use with One Piece Flexible Plastic Chrome Windshield Reveal Moulding.
1977 F100/350 from serial number O80,001 / 1978/79 F100/350 & Bronco.
The serial number is the last 6 digits of the VIN
FordIowan
07-08-2012 12:45 AM
jays66amc
06-16-2011 11:40 AM
Ira Brown
01-25-2008 10:38 PM
