Ideas to enclose and waterproof headlight relays? - Ford Truck Enthusiasts Forums
Old 10-29-2012, 08:35 PM
ryanmad2000's Avatar
ryanmad2000 ryanmad2000 is offline
ryanmad2000 is starting off with a positive reputation.
I finally got my dash wire harness mess figured out by getting the H,L and G squared away on the headlights - I put in two relays per the attached picture and they are placed on the right side interior fender along the route of the normal headlight harness lead. Does anyone have any suggestion how I can enclose these to waterproof them - 'box' would need to be about 6 inches long (to wrap in the circuit breakers) 2 inches wide and maybe an inch high. Love to have a snap lock, waterproof, black box and I'll put the holes in each end to receive wires. Been looking around on web but hard to find exactly what I need without buying 10,000 of them from China. Any ideas?
[IMG]http://www.ford-trucks.com/forums/picture.php?albumid=31078&pictureid=113
Old 10-29-2012, 08:37 PM
Try again on pic.....
Old 10-29-2012, 08:40 PM
another try at pic
Old 10-29-2012, 08:54 PM
Now that I am an expert on posting pictures, here is the wiring diagram i used which maybe will be helpful to someone else.....everyone says use relays but darn if I could find a how-to on this site........
Old 10-29-2012, 09:18 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Nice work, glad you figured it out. Any way you can put these connections back up under the dash, I know it means redoing them but now you know how it won't take as long. Just a suggestion.
On the other hand, you could glue up a box out of plexi or something but to me it seems like more work than running longer wires and putting them under the dash!
Take my opinion, I'm not using it!
Old 10-29-2012, 09:25 PM
Dash thought
Hmmm, thanks - I was so focused on the relays and the how-to I didn't consider 'where' until after. From what I could read, the real purists would say to have those relays as physically close to the battery as possible but would not be an issue to move the mountain under the dash - now that I finally understand the wiring I feel like the mountain is on wheels and would be no big deal to move (once Ms. Sandy passes by!)
Old 10-29-2012, 10:36 PM
THartman THartman is offline
THartman is starting off with a positive reputation.
You can put them in an electronics project box if you don't want to relocate them. They come in different sizes and are essentially a plastic box with a lid. Just drill holes for the wires in the side and put a dab of RTV or use grommets where the wires go in. For your specific case with the two relays, relocating them would probably be the cleanest.
Old 10-29-2012, 10:51 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Mine are approximately where yours are,but on the inside drivers fender well. I also have at that location an auxiliary fuse panel, a marine grade Blue Sea one from West Marine.Also there is horn relay I installed, and a relay for my auxiliary lights.Banking the fuse panel and all the relays together seems easiest to me, and it looks very clean in my opinion.It better, I'm an electrician. When I did the work, I made sure to use the superior quality(vs. Autozone) Bosch relays. They were German made at that time,prolly not anymore.They are quite weather-proof.
Those relays will be fine,as located,no real need to move them. We have very wet winters here, not like Gary , but still 50- 80 inches from about Oct. to April,never had a problem with any of the relays
Old 10-30-2012, 01:52 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
I'm hoping that the relays are weather proof enough on their own. Mounted mine in the same general area.
[IMG][/IMG]
Here is an article on using relays from FTE articles/specs by John Niolon
Old Trucks: Using Relays to Control High Amperage Circuits .: Articles
Old 10-30-2012, 05:37 PM
Shrink Tubes!
Ah - you sent me a subliminal message to shrink tube the leads! I had not done that. You have a tight set up there - looks great! My relays did not have mounts so right now they are flopping around....
I am going to get a box from here.....
Project Boxes | AllElectronics.com
Looks like a real good selection.
Many Thanks!
Old 10-31-2012, 10:34 AM
jmf66's Avatar
jmf66 jmf66 is offline
jmf66 is starting off with a positive reputation.
Water won't bother the relays if you turn them upright (terminals on the bottom). You can then work to weatherproof the wire terminals. Dielectric grease is great to help prevent corrosion.
Building a waterproof truck, Lubercating motors,Cleaning IP.. Seriously?! What else?! Cruiseomatic 1987 - 1996 F150 & Larger F-Series Trucks 9 10-20-2016 09:39 AM
Headlight Harness & Relay "Upgrade" BadDogKuzz 1999 - 2003 7.3L Power Stroke Diesel 85 03-09-2016 12:38 PM
Electrical Connector Rusty_S Electrical Systems/Wiring 4 09-10-2015 09:09 PM
Slow cranking start & radio static SGorman13 1999 - 2003 7.3L Power Stroke Diesel 0 08-26-2015 08:37 PM
waterproofing the ignition F350idiford 1978 - 1996 Big Bronco 5 04-12-2012 04:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
