trans guts - Ford Truck Enthusiasts Forums
trans guts
Old 10-29-2012, 08:33 PM
Triggh4 Triggh4 is offline
Triggh4 is starting off with a positive reputation.
trans guts
I know I've posted just about every question about transmissions known to man over the past few weeks but Im still having issues.
So here we go, my DD is a 75 F150 2wd, with a 390 and C6. The parts truck is a 78 f150 2wd, with 351M and C6. Long story short again DD wont go into 2-3 when in (D) and I can Manually shift it to 1st and 2nd but it wont go into 3rd. Yes Reverse and Park work.
I know the C6 transmission cases are different between the two trucks. Now my wife asked me, " Well why dont you just swap the guts in the transmissions." And I said to myself, Hmm I think shes on to something.
So here I am with the million dollar question. Can I put the internals from a 351M C6 into a 390FE C6.
Old 10-29-2012, 11:41 PM
thekingofcows's Avatar
thekingofcows thekingofcows is offline
thekingofcows is gaining momentum as a positive member of FTE.
Yep, just not the torque converter, but I wouldn't go to the trouble to swap parts without a rebuild kit anyway, its not worth the time to have some rubber seal rot and start leaking three months after you swap internals.
Old 10-30-2012, 12:06 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
You have to completely disassemble the trans to swap the tail shafts so you might as well just rebuild what you have. Do not reuse the TC from the bad trans, there is no way to flush one out and be sure to flush your lines and cooler out real good.
Old 10-30-2012, 12:39 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Yup, you can pretty much swap all the parts. But, like thekingofcows and mark a. said, you might as well throw in a rebuild kit. You're going to have to tear it down regardless, at least you'll know what you've got.
With the transmission not shifting into third, the three areas I would pay close attention to while the tranny is torn down is the vacuum modulator, the valve body and the governor assembly. Any of these three could cause the symptoms you describe.
And X3 on replacing the torque converter and X2 on flushing the cooler lines, a lot of people overlook that one.
Old 10-30-2012, 03:14 PM
thanks for the help got a recommended rebuild kit and TC opinions.
Old 10-30-2012, 10:31 PM
mark a.'s Avatar
I get most trans parts from Oregon Performance Transmission.
Old 11-07-2012, 06:08 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
I got my rebuild kit from rock auto. I've been very happy with them with everything I've bought.
85 F150 stalling out Facio Visaya 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-04-2016 05:20 PM
1976 F150 Supercab 390 to a 302/351w kadrocker Engine Swaps 4 01-26-2016 11:59 AM
New purchase, a-lot of work ahead! cgi2099 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 07-30-2015 10:01 PM
C6 question Triggh4 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-19-2012 11:15 PM
Engine question. 351w or 390 kcode 1973 - 1979 F-100 & Larger F-Series Trucks 13 11-18-2011 11:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
