Top Dead Center Mark? (injector pump gear alignment) - Ford Truck Enthusiasts Forums
Closed Thread
Old 10-29-2012, 04:33 PM
PJRay PJRay is offline
PJRay is starting off with a positive reputation.
Hoping for a little info. Made the mistake of removing the injection pump drive gear with my IP. And nope I don't have it marked . Now I'm wondering if it's possible to use a mirror to look between the drive gear and the front engine cover to match the timing marks, or do I really have to remove the front cover and everything else?
Old 10-29-2012, 04:37 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Do some searching. using a mirror, a light, and some putty / playdoh you can find where you need to be. Im sure someone will chime in here with the links. It really does need to be made a sticky
Old 10-29-2012, 04:43 PM
Thanks!
It looks like there's about 1/4 inch between the gear and the cover, and maybe one of these flexible mirror covers might work. I think I was off by a tooth or two when I took off the IP with the gear. Do you know if the timing mark on the vibration damper gives me a hint if I am close?
Old 10-29-2012, 05:26 PM
RacinNdrummin's Avatar
RacinNdrummin RacinNdrummin is offline
RacinNdrummin is gaining momentum as a positive member of FTE.RacinNdrummin is gaining momentum as a positive member of FTE.
The first time I installed my pump, I had to do it like this. Basically all I did was bring the balancer to the 0 mark on the pointer, then I counted 17 teeth on either side of the "Y" to the bottom of the timing cover on each side, to center the "Y"... I was careful not to rotate the gear putting it on, and I got it first try. Just take your time, and do things carefully, and you should be able to knock it out first try.
Old 10-29-2012, 06:17 PM
Hmm, I think your on to something. Thanks a bunch! My marks on the plate that's in front of the damper are worn. Is the 0 mark directly on the center of the plate?
Old 10-29-2012, 06:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
ask and you shall receive.
"Talk about Timing!!"
http://www.ford-trucks.com/forums/11...pump-gear.html
http://www.ford-trucks.com/forums/10...ning-info.html
Old 10-29-2012, 07:00 PM
Thank You!!!
This is awesome! Thanks. Hopefully I'll get this beast back together.
Old 10-29-2012, 07:36 PM
therifleman556's Avatar
therifleman556 therifleman556 is offline
therifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputationtherifleman556 has a superb reputation
Mods:
Sticky, please.
Thank you.
Sincerely,
IDI Local 445/420
Old 10-29-2012, 10:02 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Quote:
Originally Posted by therifleman556 View Post
Mods:
Sticky, please.
Thank you.
Sincerely,
IDI Local 445/420
Ask, and you shall receive
I locked the thread to try and keep it clean for the next guy. If the original poster still needs help, he can open a new thread if that's ok.
Closed Thread
Timing concerns and questions gooldg 1987 - 1996 F150 & Larger F-Series Trucks 5 03-30-2015 08:55 AM
Aligning the pump gear. akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 07-10-2014 02:51 PM
Timing Chain Replacement - Alignment Marks? rickm15752 1968-2013 Full Size Vans 4 01-05-2012 05:00 PM
1987 4.9 timing gear replacement mcne 1987 - 1996 F150 & Larger F-Series Trucks 2 10-12-2010 03:37 PM
1987 F-150 4.9 timing gear replacement mcne Ford Inline Six, 200, 250, 4.9L / 300 9 11-20-2005 07:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
