P0401 Exhaust Gas Recirculation Flow Insufficient detected
Old 10-29-2012, 04:01 PM
nutmg1's Avatar
nutmg1
nutmg1 is offline
I recently changed my EGR valve, Oil and EGR cooler. Since replacing those I have no upper end power. IE when driving 55mph if I floor it I get no acceleration, or boost. My turbo was replaced 6 months ago. I get up to 21 boost when coming off the line but nothing at upper speeds.
Codes are P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P132B No description Found in DTC database.
Any ideas where I should start? I have a cold air intake and I'm going to clean the filter but I doubt that has anything to do with it.
Old 10-29-2012, 05:35 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
What year is your truck?
Here are a couple things I found:
https://www.ford-trucks.com/forums/1...132b-code.html
https://www.ford-trucks.com/forums/1...ck-of-dtc.html
Any way to read any PIDs? Like EB and MAP? VGT%?
Old 10-29-2012, 06:58 PM
Fal-308-Win's Avatar
Fal-308-Win
Fal-308-Win is offline
P132B= turbocharger/supercharger boost control "A" performance
Old 10-29-2012, 07:01 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
The stock air filter is really terrific and
Does a far better job of protecting your
turbo from dirt. Ditch the after-market one.
Old 10-29-2012, 07:09 PM
Mich6.0's Avatar
Mich6.0
Mich6.0 is offline
OIL SOAKED MAF SENSOR MAYBE
Old 10-29-2012, 11:17 PM
nutmg1's Avatar
nutmg1
nutmg1 is offline
Kind of wierd on the year. The door says 2003 but the motor is early 2004.
Thanks for the links. I'll check them out.
Old 10-29-2012, 11:20 PM
nutmg1's Avatar
nutmg1
nutmg1 is offline
I wish I had the stock filter. I don't see the difference except I need to clean this one alot more.
Old 10-29-2012, 11:21 PM
nutmg1's Avatar
nutmg1
nutmg1 is offline
Thanks I'll check that out. It would be great to find something simple like that.
Old 10-30-2012, 05:45 AM
bismic's Avatar
bismic
bismic is offline
Received 2,484 Likes on 1,722 Posts
P132B is a code related to the calibration from the recall 06E17 (part of the Inferred EBP strategy). It means that there is a problem with the VGT system. P132B is a fault code that is set if the required boost levels are not achieved during a learn cycle or at specific speed fuel demand points. This code indicates that there are issues with the turbocharger, MAF sensor, MAP sensor/hose, IAT2 sensor, intake leaks, or exhaust leaks, etc. Frequently it is a sticking turbo issue. This code can also throw a P0401 EGR code.
Cshel87
10-12-2014 08:29 AM
wingrider75
02-22-2014 10:41 PM
PaulwestSki
01-18-2013 11:21 PM
rshelton
05-15-2009 12:49 PM
WishIhada7.3
03-11-2007 09:42 AM
Quick Reply: P0401 Exhaust Gas Recirculation Flow Insufficient detected
