P0401 Exhaust Gas Recirculation Flow Insufficient detected - Ford Truck Enthusiasts Forums
Old 10-29-2012, 05:01 PM
nutmg1 nutmg1 is offline
nutmg1 is starting off with a positive reputation.
I recently changed my EGR valve, Oil and EGR cooler. Since replacing those I have no upper end power. IE when driving 55mph if I floor it I get no acceleration, or boost. My turbo was replaced 6 months ago. I get up to 21 boost when coming off the line but nothing at upper speeds.
Codes are P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P132B No description Found in DTC database.
Any ideas where I should start? I have a cold air intake and I'm going to clean the filter but I doubt that has anything to do with it.
Old 10-29-2012, 06:35 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
What year is your truck?
Here are a couple things I found:
http://www.ford-trucks.com/forums/10...132b-code.html
http://www.ford-trucks.com/forums/11...ck-of-dtc.html
Any way to read any PIDs? Like EB and MAP? VGT%?
Old 10-29-2012, 07:58 PM
Fal-308-Win's Avatar
Fal-308-Win Fal-308-Win is offline
Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.
P132B= turbocharger/supercharger boost control "A" performance
Old 10-29-2012, 08:01 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
The stock air filter is really terrific and
Does a far better job of protecting your
turbo from dirt. Ditch the after-market one.
Old 10-29-2012, 08:09 PM
Mich6.0 Mich6.0 is offline
Mich6.0 is starting off with a positive reputation.
OIL SOAKED MAF SENSOR MAYBE
Old 10-30-2012, 12:17 AM
Kind of wierd on the year. The door says 2003 but the motor is early 2004.
Thanks for the links. I'll check them out.
Old 10-30-2012, 12:20 AM
I wish I had the stock filter. I don't see the difference except I need to clean this one alot more.
Old 10-30-2012, 12:21 AM
Quote:
Thanks I'll check that out. It would be great to find something simple like that.
Old 10-30-2012, 06:45 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
P132B is a code related to the calibration from the recall 06E17 (part of the Inferred EBP strategy). It means that there is a problem with the VGT system. P132B is a fault code that is set if the required boost levels are not achieved during a learn cycle or at specific speed fuel demand points. This code indicates that there are issues with the turbocharger, MAF sensor, MAP sensor/hose, IAT2 sensor, intake leaks, or exhaust leaks, etc. Frequently it is a sticking turbo issue. This code can also throw a P0401 EGR code.
HELP! Truck Stalled, Won't Start, & Have OBD Codes flare-f150 1997 - 2003 F150 1 07-20-2015 07:42 PM
2001 f-150 code 0401 4.2L br54niner 1997 - 2003 F150 9 10-04-2014 11:39 PM
2006 f250 power stroke "going code crazy" Santo Claus New Member Introductions 5 06-02-2014 03:50 PM
My 6.4 Problems continue.... Mudslinger72315 6.4L Power Stroke Diesel 7 12-26-2013 12:56 AM
EGR code 401 96 f150 droppedf100 1987 - 1996 F150 & Larger F-Series Trucks 2 06-30-2010 05:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
