Ip rebuild parts - Ford Truck Enthusiasts Forums
Ip rebuild parts
Old 10-29-2012, 04:07 PM
bduemig's Avatar
bduemig bduemig is offline
bduemig is starting off with a positive reputation.
Ip rebuild parts
Does anyone know what parts should be replaced and what parts can be inspected and reused when rebuilding nan IP?
Old 10-29-2012, 04:14 PM
RacinNdrummin's Avatar
RacinNdrummin RacinNdrummin is offline
RacinNdrummin is gaining momentum as a positive member of FTE.RacinNdrummin is gaining momentum as a positive member of FTE.
All sealing and wear parts need to be replaced... Those are fairly cheap. As long as the head and rotor are in good shape, and dont fit "loose", those are fine to use. All the rest of the parts are pretty much non-wear, as long as a bunch of junk hasn't been run through the pump, or it doesnt have a million miles on it...
You need to have it recalibrated on a bench though, and normally a shop (If its a quality shop) wont touch it if it hasnt been rebuilt by them, there is too much liability...
Old 10-29-2012, 05:06 PM
hookedondiesel hookedondiesel is offline
hookedondiesel is gaining momentum as a positive member of FTE.
Check out this thread, lots of good info.
http://www.ford-trucks.com/forums/11...n-rebuilt.html
IP rebuilder Portland or bpimm Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 01-13-2017 04:06 PM
no fuel from IP to injectors Etone Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-17-2016 10:06 PM
White smoke out of tail pipe on fresh rebuild ihf-350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-20-2016 05:08 PM
7.3 IP jmuenchow Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 02-13-2015 09:17 PM
87 6.9 IP? j.g.curry 1987 - 1996 F150 & Larger F-Series Trucks 2 01-22-2015 07:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
