3 Radiators?
3 Radiators?
This is my second IDI, but I'm confused. I have a 1990 F250 Lariat with 112,000 on the clock. It's new to me as of a month ago. It has the main Radiator, a second smaller radiator in front of the main radiator and a third even smaller radiator that looks to be fairly new in fornt of both of these. Do I just trace the lines to see where they go?
The reason for this question is the temp gauge reads 165 and the chiltons manual says if an aftermarket trans cooler is installed, it will run cooler, but 165 seems way to cool.
If when talking about a temp sensor do you mean an aftermarket sensor & aftermarket gauge? If the stock temp sensor is hooked up to an aftermarket gauge you're going to be getting a false reading at the gauge and that could explain why it says your only at 165*. And just to be more clear, make sure your sensor is in one of these 2 spots, I have mine threaded into where the temp warning light sensor used to be.
Definitely sounds like your gauge and your sensor aren't compatible to one another, or one of the two just isn't working properly. That's the only thing I can think of that would lead to a temp that low. Maybe, MAYBE if the truck was run without a t-stat it'd be that could, but even that's a stretch.
Mike
Mike
86cherokeek20
11-26-2011 11:14 PM
