How to reset my cpu on my 93 f250 - Ford Truck Enthusiasts Forums
Old 10-29-2012, 01:03 PM
trajones123 trajones123 is offline
trajones123 is starting off with a positive reputation.
So ive needed to reset my "brain" on my truck, im pretty sure its an OBD-1 correct me if im wrong. Ive been told to just disconnect the negative on the battery and let it sit for a few minutes then reconnect it and it should reset but ive also heard to take out one of the fuses in the circut board to truly reset it, just need some help with this one so i dont screw anything up, thanks again!
Old 10-29-2012, 01:07 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
If you don't have a code reader that can reset, then disconnecting the battery will do it. Mine needed more than a couple minutes, but a half hour always did it...
Old 10-29-2012, 01:20 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Right, just disconnect the battery for a little while.
Never heard of disconnecting an internal fuse and I don't see how that could do anything useful unless there was electricity attached to the thing (removing the fuse would then break the circuit the fuse was protecting). These things don't have internal batteries so I can't see a need to open the thing up.
Old 10-29-2012, 04:40 PM
culterconverger culterconverger is offline
culterconverger is starting off with a positive reputation.
disconnecting and waiting will do it but if you want to speed it up disconnect both positive and negative sides and touch the wire terminals to each other this just allows and stored power to discharge completely
2012 F350 6.7l CEL reset? jason4636 6.7L Power Stroke Diesel 1 03-07-2014 01:55 PM
PCM Reset OnlyFords4Me Excursion - King of SUVs 7 11-14-2008 05:37 PM
Air filter minder won't reset superv10 6.0L Power Stroke Diesel 3 08-30-2007 06:12 AM
Scanner with reset/clear code ability? jdemaris Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 07-15-2007 11:23 PM
keyless remote and pad code reset grandaddy's66 1997 - 2003 F150 12 07-19-2004 10:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
