Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
  #1 (permalink)
Old 10-29-2012, 12:02 PM
asim04LJ asim04LJ is offline
Garage is empty, add now
asim04LJ is starting off with a positive reputation.
No Power to Fuel Sending Unit
Hey guys,
Ford noob here trying to see if others had a similar issue with no power to the fuel sending unit. First thought was the fuel gauge as its stuck on empty but I did the gauges sweep test and the thing moves. Then, we replaced the sending unit and as that didn't solve it, we checked to see if it was getting power and it is not.
So, there must be a short somewhere. There are no fuses or relay for the sending unit as far as I know and dumb me forgot to check what color is the wire to trace it. If somebody knows or can point me to the right direction, I appreciate it.
2005 F-250 6.8
  #2 (permalink)
Old 10-29-2012, 08:53 PM
BroncoRN BroncoRN is offline
BroncoRN is starting off with a positive reputation.
Is the fuel cutoff tripped?
__________________
2000 Excursion XLT 2wd 6.8l V10 3.73
2004 Trailblazer 4.2l I6 3.73
2003 Oldsmobile Alero 2.2l 4cyl
1999 Honda Shadow Aero 1100 vtwin
  #3 (permalink)
Old 10-29-2012, 09:06 PM
Quote:
Nope. Doesn't that only cutoff the fuel pump?
The truck runs fine and before power to the sending unit went completely out, the fuel gauge would intermittently go out but work again.
  #4 (permalink)
Old 10-29-2012, 09:11 PM
Sounds like bad ground.
__________________
  #5 (permalink)
Old 10-29-2012, 09:27 PM
I thought about that too but wouldn't there be one hot wire for the sending unit. When we had the new sending unit connected but not installed inside the tank, we jumped a wire from the (-) post to the ground wire on the sending unit while moving the arm and that didn't solve it for a bad ground.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
