1991 f250 xlt lariat 7.3. IDI glow plugs and wait to start not working
Old 10-29-2012, 11:44 AM
Cjambla's Avatar
Cjambla
Cjambla is offline
Question 1991 f250 xlt lariat 7.3. IDI glow plugs and wait to start not working
I have a 91 7.3 idi and over the last month it's gradually gotten harder to start. Now, as of last night the wait to start light just flashes and shuts off. It's cranking fine but won't turn over, and it is releasing white smoke. I don't think any of the glow plugs are even turning on. Do I have a bad relay or glow plug controller?
Old 10-29-2012, 11:52 AM
Phy's Avatar
Phy
Phy is offline
The first thing to check is the glow plugs them selves. The glow plug controller senses the resistance to ground through the glow plugs (which varies with heat) to determine how long to energize the plugs. With a couple burned out plugs, the controller thinks the engine is warm, and doesn't turn them on for long (the short wait to start light...)
This thread will tell you all about the system:
https://www.ford-trucks.com/forums/9...le-system.html
Old 10-29-2012, 12:27 PM
Cjambla's Avatar
Cjambla
Cjambla is offline
I looked at the forum and did what they said with the test light on checking the plugs and the plugs all made the light light up which according to the forum says they're good. Then would that mean its a bad controller?
Old 10-29-2012, 12:55 PM
Phy's Avatar
Phy
Phy is offline
I'd check the wiring from the relay to the glow plugs next. If that's bad, it can have the same symptoms... If that's good, then check the relay itself, and if the plugs, wiring, and relay are all good, then the controller is all that's left...
pjcat
02-02-2015 08:41 PM
Cjambla
11-29-2012 08:55 AM
MageBeowulf
11-13-2011 04:57 PM
taandctran
05-13-2010 12:15 PM
bigmacmonday
11-18-2009 10:46 PM
Quick Reply: 1991 f250 xlt lariat 7.3. IDI glow plugs and wait to start not working
