1991 f250 xlt lariat 7.3. IDI glow plugs and wait to start not working - Ford Truck Enthusiasts Forums
Old 10-29-2012, 12:44 PM
Cjambla Cjambla is offline
Cjambla is starting off with a positive reputation.
Question 1991 f250 xlt lariat 7.3. IDI glow plugs and wait to start not working
I have a 91 7.3 idi and over the last month it's gradually gotten harder to start. Now, as of last night the wait to start light just flashes and shuts off. It's cranking fine but won't turn over, and it is releasing white smoke. I don't think any of the glow plugs are even turning on. Do I have a bad relay or glow plug controller?
Old 10-29-2012, 12:52 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
The first thing to check is the glow plugs them selves. The glow plug controller senses the resistance to ground through the glow plugs (which varies with heat) to determine how long to energize the plugs. With a couple burned out plugs, the controller thinks the engine is warm, and doesn't turn them on for long (the short wait to start light...)
This thread will tell you all about the system:
http://www.ford-trucks.com/forums/90...le-system.html
Old 10-29-2012, 01:27 PM
I looked at the forum and did what they said with the test light on checking the plugs and the plugs all made the light light up which according to the forum says they're good. Then would that mean its a bad controller?
Old 10-29-2012, 01:55 PM
Phy's Avatar
Phy Phy is offline
I'd check the wiring from the relay to the glow plugs next. If that's bad, it can have the same symptoms... If that's good, then check the relay itself, and if the plugs, wiring, and relay are all good, then the controller is all that's left...
7.3 idi glow plug relay? Nick91 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-02-2014 09:40 PM
7.3IDI while glow plugs cycle, tach and battery gauge flicker up and down. ynoteh 1987 - 1996 F150 & Larger F-Series Trucks 4 10-22-2013 06:35 PM
88 f-250 7.3 IDI glow plug controller? bigmacmonday Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 08-21-2013 07:34 AM
manuel glow isn't always Manuel 1989f250IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-11-2013 09:22 AM
Upgrading Glow Plugs for 7.3 Luvmy7.3Ex Excursion - King of SUVs 11 12-27-2012 06:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
