54' Axel Location
Old 10-29-2012, 11:31 AM
lowtrkn2k's Avatar
lowtrkn2k
lowtrkn2k is offline
Question 54' Axel Location
Can someone please verify where the axel is located on the 1954 frame. I'm about to weld in a step notch and I have a few faint lines drawn around the axel/bump stop location from a few years back. I had dismantal pics on my computer and the file accidentally got deleted a few years back so I dont have those pics to refer too anymore. I just want to be sure before cutting and welding that I will be getting the step notch centered correctly. I'd appreciate if someone could verify where the original axel was located.
Thanks.
Old 10-29-2012, 11:36 AM
Harrier's Avatar
Harrier
Harrier is offline
Here are some dimensions from Earl's World.
Scroll down toward the bottom to get dimensions for a 53, which should be the same as the 54. This might not get you all the way, but it should get you closer.
http://www.clubfte.com/users/earl/Re...on Information
Old 10-29-2012, 12:56 PM
lowtrkn2k's Avatar
lowtrkn2k
Thanks for the reply. I've seen that chart and it doesn't give me the location. Unfortunatly it covers every location but that. I would assume it should be centered below the bump stop mount hole but since I don't have my original info just want to check before making an irriversable mistake.
Old 10-29-2012, 06:34 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
I assume your talking about a "C" notch over the rear axle and if so I recently did mine and yes if was centered between the bump stop bolt holes.
Old 10-30-2012, 09:53 AM
lowtrkn2k's Avatar
lowtrkn2k
Thanks Truckeemtnfords. That's what I thought but wanted to confirm since I installed the 4 link a few years back and my axel lines up about just a little rear of the bump stop as it is now. It would have been nice to not have lost the dismantal file I had, however most of the time I can either find pics on line or search here for what I need. For some reason this info was not coming up in text or pictures. Thanks again both of you.
classicfins
13
12-04-2008 07:09 PM
sid318
International Region
06-17-2007 01:26 AM
Max E
04-27-2007 07:17 PM
Max E
04-22-2007 08:27 PM
Kai
06-13-2002 09:57 PM
Quick Reply: 54' Axel Location
