Heating Problems - Ford Truck Enthusiasts Forums
Heating Problems
Old 10-28-2012, 11:16 PM
Kaizer88's Avatar
Kaizer88 Kaizer88 is offline
Kaizer88 is starting off with a positive reputation.
Heating Problems
Hey guys needs your help my wifes 89 f150 5.0 wont blow heat out of any of the vents. I pulled the cover off where the heater core is and checked the door its working and you can feel the heat coming off the core. But when I put the cover back on no hot air blows out the vents. Please help its starting to get cold and I hate the cold and so does she.
Old 10-29-2012, 12:11 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
Sounds like the blend door isnt working properly. How did you verify that it is working?
When a similar deal happened with my truck, there was a piece of plastic broken and wedged in the blend door so the door worked, but stayed open far enough that the heat wouldnt fully get to where it was going.
Old 10-29-2012, 03:06 PM
SOB Racing's Avatar
SOB Racing SOB Racing is offline
SOB Racing is starting off with a positive reputation.
Check all vac. lines I had a similar issue but it was cold are defaulting to defrost Most of the vac. lines are under hood on passenger side and go into truck near glove box.
1993 f150 heater problems superman7928 1987 - 1996 F150 & Larger F-Series Trucks 6 01-30-2015 04:08 PM
heat problem on my 99 f150 jagger blaze 1997 - 2003 F150 8 11-18-2014 10:40 PM
Need help..vents all screwed up. 12amracer Expedition & Navigator 3 03-14-2013 09:51 PM
Bizarre Heater Issue?!?!?!? killerklown 1987 - 1996 F150 & Larger F-Series Trucks 2 09-21-2012 08:42 AM
97 AWD partial rear heat, NEED HELP! Sir_Ham Aerostar 2 11-09-2003 11:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
