Explorer Advance Trac Problem Help! - Ford Truck Enthusiasts Forums
Old 10-28-2012, 09:31 PM
EchoEv1's Avatar
EchoEv1 EchoEv1 is offline
EchoEv1 is starting off with a positive reputation.
My battery died and now my AdvanceTrac turns off when I start my 2005 Explorer. I'm concerned with going to the dealer to reset. I don't want them to charge me out the you know what. Does anyone know how to reset the advance trac or how much Ford Dealerships charge to reset if resetting is all that's needed. Help!
<!-- / message -->
Old 10-29-2012, 06:37 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
A well-equipped independent shop may be able to at least pull the diagnostic codes for the AdvanceTrac system and may even be able to attempt the recalibration if that is what is needed. An independent shop will likely be less expensive than the dealer, at least for the scan and code reset.
My Autel DS708 has the capability to initialize and calibrate the AdvanceTrac module and I've tried it out on my 2004 Aviator. If you find a shop in your area with the DS you can be reasonably confident they'll be able to figure out what is causing the light.
-Rod
Old 10-29-2012, 06:18 PM
EchoEv1's Avatar
Thank's, I'll call around to see if a local mechanic has dealt with this before. Until then I am in the dark on this one.
HELP Derek Williams 1999 to 2016 Super Duty 7 02-14-2017 09:09 AM
Reset TPMS 2011 F350...please help! :) admorris 1999 to 2016 Super Duty 25 09-07-2016 07:14 PM
Help! Ford Sport trac fuel reset problem keener Explorer, Sport Trac, Mountaineer & Aviator 2 12-01-2010 08:48 PM
Reset oil service light?? riyo2008 Explorer, Sport Trac, Mountaineer & Aviator 3 08-04-2008 11:43 PM
02 Explorer Change oil message RESET KenFromNorCA Explorer, Sport Trac, Mountaineer & Aviator 1 03-15-2005 05:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
