66 econoline sending unit
Old 10-28-2012, 07:48 PM
SwampyBull's Avatar
SwampyBull
SwampyBull is offline
I have a 1966 econoline supervan with a bad sending unit, and I can't find one specifically for my year and model. So if there are any other vehicles I can search for that have the same unit, any help would be great.
Old 10-28-2012, 11:43 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
By "sending unit" do you mean the sensor in the gas tank? If so, they are bad about grounding, so your sending unit may be fine.
Drill a small hole in the flange in the corner of the tank. (not where gas will leak out)
and drill a hole in the van frame. Put a sheet metal screw in each hole and run a wire between the two, and see if that helps.
Old 11-01-2012, 07:57 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No such thing. There is only one sending unit for all 1961/67 Econolines.
C2DZ-9275-A .. Fuel Sending Unit / Obsolete
1961/67 Econoline / 1960/64 Falcon except Ranchero, Station Wagon & Sedan Delivery.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 18 = 606-787-5293.
But, do not buy one until you've checked the following:
The "usual" cause why the dash fuel gauge reads incorrectly, or not at all.
The fuel sending unit float is made from two pieces of copper soldered together.
Solder breaks down, gas seeps in, float slowly settles to the bottom of the tank.
COAZ-9202-B .. Fuel Sending Unit Float / Available from Ford / Carpenter sells a type that is made of one piece of brass.
Applications: ALL 1957/79 Passenger Cars/Trucks / 1961/79 Econoline / 1966/79 Bronco.
Unhook the float from the senders crooked arm, shake it to hear if gas is sloshing around inside.
Old 11-01-2012, 12:20 PM
SwampyBull's Avatar
SwampyBull
Exactly the info I was looking for, thanks for the help!
Gembone
04-30-2013 10:23 AM
Pushpin
12-19-2011 07:11 PM
jimmmack
10-19-2010 01:33 PM
66f100352
04-21-2010 05:27 AM
'nilla60
11-05-2009 05:48 PM
Quick Reply: 66 econoline sending unit
