HEIDTS CROSSMEMBER MEASUREMENT FOR A 1956 F100 - Ford Truck Enthusiasts Forums
Old 10-28-2012, 07:38 PM
s-man56 s-man56 is offline
s-man56 is starting off with a positive reputation.
Question HEIDTS CROSSMEMBER MEASUREMENT FOR A 1956 F100
Took my 56 truck completely apart .took all the springs off and cut out the engine crossmember and transmission crossmember about two years ago . now I want to install a HEIDTS IFS . I need some help on where to line it up. should of thought about this long ago.I know you have to move it forward to line up in the center of the fender opening .If some one can give me a measurement from the edge of the closest crossmember to the forward edge of the HEIDTS crossmember I would appreciate it very much. thanks for any help
Old 10-28-2012, 07:56 PM
3golfjack's Avatar
3golfjack 3golfjack is offline
3golfjack is gaining momentum as a positive member of FTE.3golfjack is gaining momentum as a positive member of FTE.
Old 10-28-2012, 10:37 PM
Smile
Thanks , all I have to do is grind off the paint where I filled the front shackle holes, the big hole, and measure from the center of it back 19 3/4 to the center of the crossmember or spindle. thanks again
TCI Custom IFS and Chassis Engineering IFS - Questions REDHTGT 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 03-03-2015 08:16 PM
Helix vs Heidts IFS coil weight ratings wallster 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-28-2014 10:28 AM
1952 F1 Front suspension help psi4gti 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 11-02-2013 08:09 PM
Can I Cut This Out? Filthy1955F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-16-2013 10:40 PM
heidts crossmember keisha9 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-15-2013 03:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
