89 f 150 clutch - Ford Truck Enthusiasts Forums
89 f 150 clutch
Old 10-28-2012, 07:25 PM
liv2roc liv2roc is offline
liv2roc is starting off with a positive reputation.
89 f 150 clutch
My son is looking to buy a 89 f 150 with a 300 -6 cylinder 4 speed in floor.
I went and drove it and the clutch is fully engaged about 1/2 inch off the floor , very hard to drive I kept choking it down. I know it is a hydraulic clutch so there is no adjustment , so what could be wrong with it? or was it suppose to be like that, I am used to driving mustangs so that's what I am used to.
Old 10-28-2012, 07:28 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Sounds like it needs a clutch.
Old 10-28-2012, 07:51 PM
Im thinking if it was the clutch it wood be the opposite, would not engage til all the way out? got to be something in the slave cylinder? but what?
Old 10-28-2012, 08:08 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
It could be air in the hydraulic system, or there's a possibility that the firewall is cracked and flexing. Also check to see if the pedal is returning all the way to the stop at the top of its travel when released. A worn out clutch will slip when power is applied with clutch engaged.
Old 10-29-2012, 06:26 AM
Volvo92906's Avatar
I read it like youre saying it wont release until youre right down to the floor and even then its still *******... That is why I say that.
Could be wrong though too.
95 cab and engine swap onto an 89 frame and tranny (clutch problems) Marteney 1987 - 1996 F150 & Larger F-Series Trucks 6 01-05-2014 02:33 PM
Clutch Issues with 89 F-250 7.3 IDI Nitro Nick 1987 - 1996 F150 & Larger F-Series Trucks 9 12-02-2013 12:56 PM
Clutch cable broke? MFogarty1996 1987 - 1996 F150 & Larger F-Series Trucks 20 04-22-2011 05:53 PM
Wondering if I need a clutch 1990F2504604x4 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 10-07-2005 10:54 PM
Clutch dropped to floor CrystalK 1987 - 1996 F150 & Larger F-Series Trucks 21 05-04-2004 08:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
