Custom gas tank? - Ford Truck Enthusiasts Forums
Custom gas tank?
Old 10-28-2012, 06:13 PM
materthegreater's Avatar
materthegreater materthegreater is offline
materthegreater is gaining momentum as a positive member of FTE.
Custom gas tank?
So I've worked on a few diesel trucks (not Fords ) and noticed that their fuel tanks are basically a round drum with a fill hole. But any gas vehicle I've worked on has a more complex tank with vapor lines and special vented caps, etc.
Is it possible to use a diesel tank on a gas truck? I'm thinking of modifying my dump bed, but the gas tank is in the way. So I was going to make a custom tank to fit my needs.
Any thoughts or reasons not to do this?
Old 10-28-2012, 06:51 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
It would work fine, you would just need to make sure the sending unit will work with your gauge.
My ONLY worry would be the GAS tank would now be outside the frame and vulnerable to impact from other vehicles
Old 10-28-2012, 08:18 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
73-87 GM trucks had outboard tanks, and nothing catastrophic ever happened. In fact, Dateline rigged a truck to explode, which resulted in GM filing a lawsuit. You should be fine.
Old 10-28-2012, 09:42 PM
Yeah, I hadn't thought of the gauge issue. I'll have to think about that...
I may just get a 38 gallon rear tank and just do away with the front one altogether. That would probably be easier anyway.
Replacement gas tank - what would work? hansol04 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-30-2016 02:43 PM
anybody mod a titan/transfer flow diesel tank into a gas ccsb darkjedi351 1999 to 2016 Super Duty 0 02-21-2016 01:33 AM
1956 under bed fuel tank smallello 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-11-2014 07:57 PM
Changing gas tank setups got a few ??s swampthang 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-21-2014 05:41 PM
Yet another thread about fuel gauges Ninra 1987 - 1996 F150 & Larger F-Series Trucks 7 10-06-2013 09:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
