Front Sway Bar Problems Bolt Dont Fit
Well I went to Ford this afternoon and took a look at a new frame spacer and it has the same amount of play that mine does with the bolt. I spoke to a tech there supposed to be their suspension guy and he says there like that and that maybe mine werent tight enough. He says that he has seen them make noise when they arent. Apparently he uses an impact on everything on the sway bar even though there are torque specs in my Haynes book. Well I drove home without the sway bar up front just the rear and there were no noises at all even over stuff that should make some big noises (I took my driver side apart in Fords parking lot to bring inside and compare and contrast. So its def something to do with that. I put it all back together used my impact and well its tight as tights going to get. We will see in the am. If all is well I think I might return the Moogs when they get here. I cant decide. I know they are a better system and design and all but if these are working its tough. I could always buy the moogs again later on when these fail or I could just keep them for later.
on
on
http://img.photobucket.com/albums/v2...k/b615d6f8.jpg
https://www.ford-trucks.com/forums/9...ml#post8844381
MikeSDK
10-08-2011 10:32 PM
jwhitetail
07-15-2011 12:11 PM
