Help please!
10-28-2012, 02:02 PM
on
Help please!
So today i removed my fuel bowl. i got the fuel bowl rebuild kit online and when i got the fuel bowl out it started raining so i decided to put fuel bowl back in and do it another day. i also had to remove tube that connects to the turbo. anyway i got everything reconnected and now the truck is running very very rough im afraid to even start it again. does anybody know what could be causing this please help ASAP!
10-28-2012, 02:03 PM
on
truck is a 97 f350 7.3 powerstroke btw
10-28-2012, 02:16 PM
Maybe your FPR screen has some crap in it? You could try to flush out your bowl with the drain lever too. Air in the lines? How long did you let it run after you put the bowl back in? Hope this helps.
Red
10-28-2012, 02:35 PM
on
didnt even run for a minute now it just stalls unless giving gas even then its running very rough and bogs down
10-28-2012, 03:49 PM
U check level of fuel in bowl?
10-28-2012, 07:50 PM
on
Fuel level was good it started and was running pretty good then all of a sudden bogged down
10-28-2012, 08:14 PM
I agree with Red about possibly air in the lines. Start it up and let it run for a few minutes and see if it clears up.
Fla.Cracker96
02-07-2014 07:44 PM
Powerstroked XLT
07-22-2011 08:52 AM
afonda
02-14-2009 06:13 PM
bigbadpowerstroke
01-20-2009 07:04 PM
ms1780
11-18-2006 12:17 PM
