1979 302- swapped heads + intake = restored compression but now coolant in oil
Old 10-31-2012, 08:05 PM
alexchavel's Avatar
alexchavel
alexchavel is offline
Retorqued intake, drained oil...
will run engine again once I can eliminate any other possibilities...
I replace the stock D80E heads with E7TE heads...
is the L shaped port you mentioned a problem with the heads I swapped for?
Old 11-01-2012, 05:53 AM
baddad457's Avatar
baddad457
baddad457 is offline
Should be no problem as far as port mismatches in your case. Were the intake bolts loose ?
Old 11-01-2012, 05:55 AM
baddad457's Avatar
baddad457
Originally Posted by tomlauten
what heads are you using some have the l shaped water ports on the old hi performance heads and it will leak through the bolt hole in the l shaped port because that bolt hole is not used on a newer intake
The heads you're talking about here are the stock 69-75 351W heads. He doesn't have them.
VictorwithaC
03-28-2017 08:53 PM
alexchavel
03-29-2013 07:21 PM
1972-34ton
03-27-2012 11:07 AM
slomafarms
12-19-2008 05:44 AM
zach5.4
1999 to 2016 Super Duty
15
02-15-2008 12:10 PM
Quick Reply: 1979 302- swapped heads + intake = restored compression but now coolant in oil
