Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 10-28-2012, 01:55 PM
asquared's Avatar
asquared asquared is offline
Garage is empty, add now
asquared is starting off with a positive reputation.
?'s about weighted tags
Hi guys, just wondering about weighted tags in NC. I haven't been able to find out much on-line. If it matters, I am in Alamance county and I run an '09 F250 w/ 6.4 PSD that I bought in January of this year. It weighs in at roughly 8500 lbs. I currently tow a 7000 lb camping trailer (with approx 1000 lb tongue weight) and am looking to upgrade to a 5th wheel that will probably weigh around 10,000 lbs loaded (the pin weight will put me over my GVWR but under my RAWR). My current weighted tags are for 10,000 lbs. This is what the dealership gave me when I told them exactly what I haul. Am I ok with this or do I need a heavier tag? Is the tag based on the weight solely in the truck or the GCWR of what I am towing? Also, if I need a heavier tag, how do I go about getting it? If I am looking at a GCWR of close to 19K do I need to get more than a standard class C license? Thanks guys. I am still new to all of this.
  #2 (permalink)
Old 10-29-2012, 06:27 AM
wp120470's Avatar
wp120470 wp120470 is offline
1967 Ford Falcon
wp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to allwp120470 is a name known to all
I would think the best way to find out the legal answer to this is to call your local lisence plate agency and talk to them because they would know more than any of us since they issue the plates.
__________________
I find the best way to get back on your feet, Is to get off your a$$.
  #3 (permalink)
Old 10-29-2012, 11:39 AM
ncheavymetal's Avatar
ncheavymetal ncheavymetal is offline
NC Chapter
2004 Ford Excursion
ncheavymetal has a great reputation on FTE.ncheavymetal has a great reputation on FTE.ncheavymetal has a great reputation on FTE.ncheavymetal has a great reputation on FTE.ncheavymetal has a great reputation on FTE.ncheavymetal has a great reputation on FTE.
Certainly check with the dmv.
From what I remember if your total truck weight, minus any towed load, exceeds 8,000 pounds you need a weighted tag. And you can get different tags for different loads and they cost accordingly. Also, you can tow up to 10,000 pounds without any issues/permits.
You don't need any commercial license for what you're hauling. I think the exceptions are if your tow rig weights more then 14,000 or your GCVWR is greater then 26,900 then you need to step up to a cdl class "c" or "b" depending on several factors.
My excursion is considered an suv and as such is exempt from weighted tags. I can have a GCVWR of 19,900 before I have to persue any special requirements.
Good luck. Let us know what you find out and give us some clarification.
__________________
James FTE NC Chapter
2004 Excursion Ltd. 4x4 V-10 3.73
Join the NC Chapter
http://www.ford-trucks.com/forums/forum88/
  #4 (permalink)
Old 10-29-2012, 09:35 PM
Crete Crete is offline
Crete is starting off with a positive reputation.
Quote:
What a bunch of malarkey.
If the trailer GVWR is over 10k and the trailer GVWR + the truck GVWR is over 26k then you need a class A.
Commercial = CDL class A.
CDL exempt, RV, farm Etc. = NonCDL class A
  #5 (permalink)
Old 10-29-2012, 10:44 PM
NC Chapter
2004 Ford Excursion
I got some of it right. Not all malarky. Got the trailer/load part right. Got the combined weight pretty darn close. Didn't get the endorsement right. Pardon me.
Why don't you share your knowledge further and assist the person with the original question.
Thanks.
__________________
Join the NC Chapter
  #6 (permalink)
Old 10-30-2012, 05:38 AM
Thanks.
I did.
Thanks.
  #7 (permalink)
Old 10-30-2012, 07:47 AM
wp120470's Avatar
1967 Ford Falcon
Well that was kinda rude. Don't sweat it NCHeavymetal. Niether you or I knew Mr. Know It All was going to join us. We were just giving information to the best of our knowledge. So chill. We are a tad bit more relaxed here in the N.C. Chapter.
__________________
  #8 (permalink)
Old 10-30-2012, 10:04 AM
NC Chapter
2004 Ford Excursion
No sweat off my back. I'll give him the benefit of the doubt and figure maybe he was having a grumpy moment. It's all good. I think everyone is just trying to help.
I think the OP is on the right track anyway. He needs to check with dmv to ensure he's legal. Let us know what you find out and give us all some clarification.
__________________
Join the NC Chapter
  #9 (permalink)
Old 10-30-2012, 11:47 PM
asquared's Avatar
Ok thanks for the info guys. I will check back when I learn more from dmv and dot.
  #10 (permalink)
Old 11-28-2012, 07:24 PM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
I wouldn't trust the DMV for a straight answer, they are clueless. I drove my f250 for 10 years pulling the same trailer with a regular tag every day without a ticket, then I got pulled and was over weight by less than 2000 lbs. I went to the DMV to find out which tag I needed and they basically asked me which tag I wanted.
If you don't tow often I would roll the dice and run a regular tag, like I said for 10 years every day with out a ticket..... My other vehicle is an Excursion and I tow a 8500# camper and I don't have to have a weight tag ever. Makes no sense.
__________________
John
2001 7.3 F-250 LB 6sp. Dump bed, Firestone air bags, DP tuner, 4" MBRP, K&N intake with 6637, in tank mods
2002 7.3 EX limited 4x4, ccv mod, edge evo, 6637, RAS, In tank mods, diesel site tranny filter, JW valve body
  #11 (permalink)
Old 12-05-2012, 06:23 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Best to go to one of the weigh scales for the trucks, there is where you will get the answer.
You will also need a dot number for anything over 10,000 lbs. You also need a medical card to drive a vehicle with a dot number.
You will also need a fuel sticker.
Any vehicle over 26,000 lbs requires a CDL class B licence. A combinated (truck and trailer) unit requires an A CDL licence
we have a 33,000 lb rollback we run from here in MD, To our property in NC, being a tow truck, the weight limit says N/A, so that you can tow. In NC, you need an apportinated ( commercial weighted) tag, so we got a $1000 fine for being 27,000 lbs, or 1,000 lbs over the lightest weight truck tag. We also got fined for no fuel sticker, as Md does not require one.
Check all this out, before you make the trip with your new rig, and wind up paying your whole vacation money away in fines.
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
"If more sane people were armed, the crazy people would get off fewer shots."
"Some people are alive because it's illegal to shoot them"
  #12 (permalink)
Old 02-22-2013, 11:24 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
1999 Ford F-250
schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.schlepprock250 has a great reputation on FTE.
fordf250guy
I know this is an old thread but I wanted to kick some information into it. In NC if you are towing a camper(TT fifth wheel toy hauler)you DO NOT have to add the weight of the camper to your truck tags.As long as the trailer/camper being towed has factory sleeping quarters,now this changes if you are towing a boat or other,but not a camper..
__________________
Phil Late'99 F-250 SuperDuty 4x4 SB CC 7.3 Magnaflow4"TurboBack SS Exhaust(muffled) DP-Tuner:No Start,Stock,High Idle,60Tow,Decel,80Tow,80Econo,120Race,Lope Idle AIH Delete OBA AutoMeter UltraLite Series Gauges Boost/Trans/Pyro Dieselsite Billet T-Stat Housing(195 Stat) BTS ValveBody Spicer/Custom Driveline(front & rear) ATS Housing HPX FRX Wrapped 6637 6.0 Trans.cooler Bellowed Up Pipes GPR LED Tank Mods Pre Pump Filter Riffraff I/C Boots W/Riffraff Plenum Inserts.50 mod Warn Hubs Prodigy P2 B.E.S.T. Map PAA Member # 34
  #13 (permalink)
Old 02-23-2013, 01:02 PM
asquared's Avatar
Quote:
Where did you find thos out? As stated above the dmv was clueless. We currently are below the truck gvwr and weighted tags with the current trailers tongue weight. The trick will he when we buy the 5th wheel we want. The new 5th wheel would be around 12000 lbs loaded and would have a pin weight of around 2400 lbs. This would put me over the weighted tag weight and over my gvwr but under my rear gawr. We just want to be legal but they don't make that easy.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
