?'s about weighted tags - Page 2 - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
Old 01-11-2014, 11:03 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Here are the federal rules for the commercial requirements:
All Regulations - Federal Motor Carrier Safety Administration
For a NC driver license, you need a class A to tow anything more than 10,000 lbs. It can be classified if the use is not for commercial purposes. A medical card is required to operate a vehicle or combination over 10000 GVWR or GVW for commercial purposes even if a CDL is not required. Fuel tax laws are covered in the federal DOT rules and I believe only apply to commercial vehicles.
Here is the NC general statues for motor vehicles:
North Carolina General Assembly - General Statutes - Chapter 20: Motor Vehicles.
License tags for trucks (property hauling vehicles) are section 20-88. Truck tag includes the loaded weight of any trailer being pulled. I could not find any special exemption for travel trailers.
Old 01-11-2014, 01:57 PM
crown14 crown14 is offline
crown14 is starting off with a positive reputation.
Quote:
Originally Posted by dustybumpers View Post
I guess you missed the part about it was a Rollback ( flatbed wrecker)
This truck would be weighted at 33,000 lbs, and requires a CDL driver. This truck DOES require a fuel sticker. I have the ticket (fine) to prove that
This is also a two year old thread.
I didn't miss it, but I guess you missed the original post, clearly the discussion here is about pickups and not rollbacks.
The age of the thread has nothing to do with your off-topic, misleading post.
Old 01-11-2014, 03:52 PM
Quote:
To clarify- this would only apply to someone towing a loaded trailer that weighed over 10k, and not to someone towing a 4k trailer behind a 6k lb truck.
Thank you for verifying that. Also I am unaware of any exemption to travel trailers, however there are some exemptions of other sorts for motorhomes that I am not familiar with, this may be what has led to the confusion with the travel trailers. Also, SUVs are still exempt from weighted tag requirements.
Old 01-11-2014, 06:34 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Off-topic miss-leading post????
I'm not here to argue with you.
I said in my first post to go to the weigh station, and find out the laws.
I stated my experiance with my truck. In which I should have checked with the local laws first
I also stated the law, as I know it having a FEDERAL DOT number
I am not going to go through old threads and pick at a poster.
Anyone can "side read" what they want in someone else's post, and twist it into something else
If you want a battle, find someone else to battle with, I am uninterested
Old 01-13-2014, 11:22 AM
ncheavymetal's Avatar
ncheavymetal ncheavymetal is offline
NC Chapter Czar
ncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to behold
Not sure why things are getting off track. Try to keep on topic as best as possible and put aside any personal stuff.
I think everyone is just trying to help. We all have different trucks and haul different stuff. So far some good information has been shared. Like many threads of this nature it will be up to the OP to weed through all the info and make their own decision.
I hope folks continue to share the information they know about weighted tags and provide a source/reason for that knowledge. We may eventually have a very informative thread that can be broken into categories based on specific information.
Old 01-21-2014, 12:58 PM
Crete Crete is offline
Crete is starting off with a positive reputation.
That isn't true.
The only time the 10k+ trailer comes into play is when the combined GVWR is over 26k.
Class A.
Quote:
Any combination of vehicles with a gross vehicle weight rating, GVWR, of 26,001 pounds or more, provided the GVWR of the vehicle or vehicles being towed is in excess of 10,000 pounds.
NCDOT: Commercial Drivers (CDL)
Old 01-21-2014, 06:20 PM
EPNCSU2006's Avatar
Thanks for the correction - it looks like they changed the towing restriction for class C recently. I have class C CDL and it has the same restriction on the back as my old non-CDL class C - trailer up to 10,000lbs, no mention about combined weight (or age for that matter) when towing.
Non-CDL descriptions from: NCDOT: License Fees
Class A:
Quote:
Required to operate any combination of vehicles exempt from CDL requirements with a gross vehicle weight rating (GVWR) of 26,001 pounds or more, provided the GVWR of the vehicle(s) being towed is greater than 10,000 pounds.
Class B:
Quote:
Required to operate any single vehicle with a gross vehicle weight rating (GVWR) of 26,001 pounds or more that is exempt from CDL requirements, or any such vehicle while towing another vehicle with a GVWR of 10,000 pounds or less.
Class C:
Quote:
Required to operate any single vehicle that is not carrying hazardous material in quantities required to be placarded or is designed to carry no more than 15 passengers including the driver with a gross vehicle weight rating (GVWR) of less than 26,001 pounds; or any vehicle towing a vehicle which has a combined GVWR of less than 26,001 pounds operated by a driver at least eighteen years old.
Most drivers need only a Regular Class C license to operate personal automobiles and small trucks.
Help Me Understand My Truck's Capabilities AKHunter93 1987 - 1996 F150 & Larger F-Series Trucks 27 05-09-2016 05:42 AM
Weight rating and VA registration question 93-331-29PSI 6.7L Power Stroke Diesel 4 12-10-2015 01:04 PM
Goosneck trailer towing and weight in Pa questions nverstopwheelie Fifth Wheel & Gooseneck RV Towing 7 02-20-2015 09:16 PM
How Do I Select The Right Tow Strap? CTC01 Offroad & 4x4 29 01-04-2014 03:27 PM
5th Wheel Towing Weight Limitations rflamm 1999 to 2016 Super Duty 8 10-24-2002 07:41 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
