Problems Starting Truck. - Ford Truck Enthusiasts Forums
Old 10-28-2012, 10:02 AM
MidwestKid34 MidwestKid34 is offline
MidwestKid34 is starting off with a positive reputation.
Howdy
I am having problems starting my F150. When I turn the key to the on position I have power, lights turn on etc. When I turn the key to start it, I hear a single click noise and lose all power.
After I lose power it stays that way for about a minute with the key in the on position. After a minute of no power with they key in the on position, the power turns on again.
I believe the starter and solenoid are good. Any ideas what could be the problem? Bad ground?
Thanks!
Old 10-28-2012, 10:08 AM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
Originally Posted by MidwestKid34 View Post
Howdy
Thanks!
Clean your battery cable clamps first!!!! If that doesn't do the trick check the rest of the battery cables,, BOTH ends!!!
Old 10-28-2012, 10:10 AM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
Sounds like you have a bad connection somewhere, could be on either positive or negative side. Check all your battery cables for loose connections and corrosion and clean all connection points with a wire brush or sandpaper so they have a nice clean metal on metal contact. You might also have cables that need to be replaced. If the cables are all original, It wouldn't be a bad idea to just replace them all anyway.
Old 10-28-2012, 10:41 AM
danman282 danman282 is offline
danman282 is starting off with a positive reputation.
Check cables
I had a similar problem and after cleaning all connections replacing some parts, I found it to be the positive battery cable. Even though I cleaned and re-stripped the wire and everything , there was corrosion inside the cable about an or 2 up cable. Cut it off re-stripped and hooked everything up, problem solved.
Old 10-28-2012, 07:37 PM
Cables!
Ding Ding Ding, cables!
1980 F100 turn key, won't start then everything dies. Uncle Paul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-22-2014 10:33 AM
2003 F150 will turn over but not start sionkop67 1997 - 2003 F150 2 10-25-2013 06:31 PM
1987 ford f250 ignition Bigal700 1987 - 1996 F150 & Larger F-Series Trucks 2 12-16-2012 03:44 PM
Possible Electrical Problem, or Just Battery? burninrubber2416 1987 - 1996 F150 & Larger F-Series Trucks 29 10-11-2008 09:34 AM
1990 F150 ignition cylinder problems mva5142 1987 - 1996 F150 & Larger F-Series Trucks 4 09-06-2006 11:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
