Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
70 351 W
Old 10-28-2012, 04:34 AM
1930 Dodge's Avatar
1930 Dodge
1930 Dodge is offline
70 351 W
I am needing information on whats needed as far as making the belts work on this engine since I have removed the P.S pump. Originally the crankshaft pulley and the alt. are running together.
The water pump has a single groove pulley and it does not line up with the others ( too far back ) so I need to get that water pump spinning.
What should I be looking for specifically as far as either changing the water pump pulley or changing something else.
Surely this was done factory on some applications and again I just need to know what parts I should be looking for. Thanks
Old 10-29-2012, 09:27 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1970 351W would be from a car, since 1975 was the first year for Econolines and 1981 for F150/350 & Bronco's.
So, what you want is the 1970 car belt set up without P/S, that may be hard to figure out, as all came with P/S.
Galaxie/LTD, Fairlane/Torino, Mustang/Cougar.
Old 11-24-2012, 05:01 PM
1930 Dodge's Avatar
1930 Dodge
It was easier than I thought, figured it out this A.M and it did not cost me 10 cents.
Moved some stuff around, got rid of some brackets ect ect.
Id post a picture but evidently Im not allowed for whatever reason.
Old 11-25-2012, 12:51 AM
1969furd's Avatar
1969furd
1969furd is offline
you have to use external photo hosting site
Old 11-26-2012, 04:49 PM
1930 Dodge's Avatar
1930 Dodge
Do not have one of those but thanks
Old 11-26-2012, 05:37 PM
1969furd's Avatar
1969furd
1969furd is offline
Photbucket is what i use. It is simple. Bowever there are more choices out there
Old 12-01-2012, 03:09 AM
1930 Dodge's Avatar
1930 Dodge
Evidently I do have a photobucket account, I guess I opened it and then forgot about it, anyway here is link to a ( poor maybe ) picture of the new set-up. I can take better photos if anyone wants one.
I did not have to cut or modify a thing to make this work, just got rid of the two top brackets, bolted the Alt. directly to the head and used the original lower bracket or slider. http://s675.beta.photobucket.com/use...ml?sort=3&o=16
money pit 69
11-29-2014 12:26 PM
money pit 69
Engine Swaps
11-27-2014 08:20 PM
mercman65
07-18-2009 09:46 PM
imlowr2
05-23-2005 08:50 PM
beartracks
22
09-02-2004 10:35 AM
Quick Reply: 70 351 W
