Aluminum Diff Cover(s)
Old 10-27-2012, 05:46 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
Tuxedo Scorpion is offline
any good leads on some good covers?
Old 10-27-2012, 06:26 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
You only want to do the rear, it's what needs the cooling. Aluminum on the front, not so great. Try auto parts resellers from wrecking yards, compare to buying over the counter. I believe the 6.4 almost all got the aluminum covers. There are also some aftermarket you can buy at parts stores. I haven't bothered here where it's mostly so cold, it's not an issue for me. If you are dong max towing frequently I can see some benefit though.
Old 10-27-2012, 06:29 PM
slowmans's Avatar
slowmans
slowmans is offline
I have seen the ford aluminum finned cover on Ebay for like $50...
Old 10-27-2012, 06:46 PM
Tuxedo Scorpion
anyone have pics of the 2011 6.7 aluminum cover?
Old 10-27-2012, 07:41 PM
farmerdave's Avatar
farmerdave
farmerdave is offline
Old 10-27-2012, 07:42 PM
slowmans's Avatar
slowmans
slowmans is offline
isnt it the same as the 08+?
Old 10-27-2012, 07:43 PM
Tuxedo Scorpion
They didn't put em on the 12's for some reason. Guess they didnt figure they needed em
Old 10-27-2012, 07:51 PM
Hdslider's Avatar
Hdslider
Hdslider is offline
Cost more than a stamped steel.
Old 10-27-2012, 07:53 PM
Tuxedo Scorpion
Well ya, but and if it was crucial it would have it. And since it's likely not, it went
Old 10-28-2012, 06:32 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
I think the rear end was determined to not get as hot as they thought it would in the 08-10's.
I'd switch though if you tow long distances and tow pretty heavy. Especially in the hotter climates.
Old 10-28-2012, 09:15 PM
los341's Avatar
los341
los341 is offline
That's interesting. My '12 has an aluminum finned diff cover.
Old 10-28-2012, 09:17 PM
Tuxedo Scorpion
guessing its a job 1 with a composite oil pan...
Old 10-28-2012, 09:27 PM
los341's Avatar
los341
los341 is offline
Yes it is.
Old 10-28-2012, 09:30 PM
Tuxedo Scorpion
im good without the composite pan (unless is had a threaded drain plug somehow, but thats neither here nor there) but im kinda wanting the aluminum covers now. anyone know about Mag-Hytec covers? they seem like the ticket...
Old 10-28-2012, 09:33 PM
jetpilot2's Avatar
jetpilot2
jetpilot2 is offline
Here's my '12 OEM cover.
Quick Reply: Aluminum Diff Cover(s)
