Transmission mounts - Ford Truck Enthusiasts Forums
Transmission mounts
Old 10-27-2012, 01:41 PM
John Peterson John Peterson is offline
John Peterson is starting off with a positive reputation.
Transmission mounts
I purchased A transmission mount, part number 4436 from Midfifty , ccp part # is cp 4136. To mount to my C-4 transmission , in a 1956 F-100. Do I need a transmission pad also? Thanks John
Old 10-27-2012, 01:48 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Quote:
If by pad you mean the rubber and steel piece that goes between the transmission and the mount, yes.
http://midfifty.com/item.php?INV_ID=1794
Old 10-27-2012, 07:26 PM
Thanks, I didn't Know what they looked like.And did not know I needed one. I did pick one up at my local auto parts store . A Parts master transmission mount part number 2253 for a 1966 Ford Fairlane w/ a C-4 tran
AC compressor replacement john jamieson Ranger & B-Series 3 08-25-2015 07:02 AM
51 column shift 3 speed John Morton 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 11-24-2008 12:55 PM
Engine lift plate john fin 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 09-16-2008 07:16 PM
Transmission code chart Fast John ll Clutch, Transmission, Differential, Axle & Transfer Case 1 07-12-2005 11:05 AM
Which transmission do I have? John7894 1987 - 1996 F150 & Larger F-Series Trucks 10 07-14-2002 07:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
