my husband
my husband
ok so my husband bought a 1995 f150 5.0 and was told the only problem with it was an ECM. First question is what the h@#$ is an ECM? second if that isnt the name can you please help us figure out what is wrong with it? The battery is fully charged but will not turn over. Please help before I kill him.
Jumping the gun, get it to crank first then determine failure to start if it fails to start.
The ECM is not the reason for it failing to turn over, correct that issue first.
I would say pull the starter and either bench test yourself or run it up to your local autoparts store and have them test it. If it test bad start with replacing it. If it tests good replace the solenoid and all 3 battery cables( battery to solenoid, solenoid to starter, negative cable) Make sure the battery is grounded to both the block and the body.
Matt
Matt
ShortBed'86
21
07-25-2016 05:56 AM
Volkelrunner74
31
10-19-2013 06:53 PM
CaperFord
38
01-29-2012 04:53 PM
